A small thing I did...And I had carpet in the room (not my choise)
I tried this when living in the US (in a flat/townhouse). I ended up working with the big slab in my knee, simply to much noice whatever I tried. For the moments I really needed something more I had a high stool (wood, from K-Mart I think) but I tried to use that as short periods as possible not to disturb my neighbors. My best tip is to talk to your neighbors, show them some of what you're making and they will (might) have more patience with the banging:-)
"He who works with his hands is a laborer.
He who works with his hands, and his head is a craftsman.
He who works with his hands, and his head, and his heart, is An Artist"
http://vildkorpens-laderlya.deviantart.com
http://tupali.deviantart.com/
thicker slab seems to help too.I sometimes use 2, one on top of the other,Edward
You could also try using the grey duct tape just put about a one inch wide strip around the end of each tool used and leave a little above the top of tool and kinda push down on it to give that fluffy shock type of hitting section of tool. Since my accident I have very bad insomnia so I try to not wake the wife when I am just having a ball!!!! not being able to sleep some nights. This type of tape methiod reduces the noise down to about half, but makes your hits a bit lighter so really watch how your tooling is working. The best about my circumstance is, she also wears ear plugs as a habit so I never actually wake her , which is just luck in my case
Still trying to figure out what is going on out there in the custom/one off world
rubber mats (4by8 sheets) used to line trailers are cheap and work well under table and chair ,,,keep feet off cold floor ,,,sold at MCOYS farm and ranch setting outside as you walk in store ,,,,,,,,,,,,,,about 3/4 inch thick.................
  • 7 months later...
Wow, can't believe no one came up with this:
I use an oak 6x6 standing on end between my legs. What noise?
I want to graduate to an oak log 12" in diameter or more at work bench level.
Every one I meet is in some way
superior; They know something that I don't
and in that I can learn from them.
An open mind leaves a chance for
someone to drop a worthwhile thought in it.
As a 3rd floor apartment resident, I can completely understand. Reducing noise is 2 parts -
1. Contact noise - or the sound your hammer makes hitting the tool, and there's not a whole lot you can do except use a different mallet. Rawhide or plastic striking face, then soundproof your walls a bit.
2. Vibration transfer - if the blow gets to the floor and shakes someone's ceiling and walls. Here, you can do a lot, and it comes down to mass and absorption. I used to have a stack of 8 concrete blocks, 4 high, thick carpets between each, poundo and granite on top, and you could set rivets all night long and wouldn't wake a baby. Only problem is 200lbs of concrete took up a bit of space, so I've 86'd that and am just using a few carpet pieces and the stone on a heavy bench, with some chunks of carpet under the legs.
If it's still not enough, I just turn up the radio a touch and keep the pounding to the daylight, 10 am -10 pm, and spend the nighttime cutting out parts, sewing, swivel knife work, dying, edge finishing, and designing your next project or cutting pattern.
  • 3 months later...
Same problem, tried everything possible, it's not working. So far trying to watch closely when neighbors go out, and trying to use this time for louder work. Occasional work is OK, but no way enough for making leatherworking a profession working from such home, with volume production, and for riveting or tooling.
two things I can suggest. Put the 12x12 slab in your lap to set rivets or whatever. When I first started I just sat indian style in the floor with the slab in my lap, but I've always been limber so maybe it won't be comfortable for you like that.
Second thing is get a 55lb anvil from harbor freight. Its poorly cast junk which means there won't be any loud ringing because its not a real anvil, but even so its heavy enough to dampen the traveling noise for the most part. They used to be around $35 and its likely to come on special at some point too.
Elaborate Custom Armor, Weapons, And Leather Items at PrinceArmory.com | My DeviantArt Gallery | Facebook |
