Members rccolt45 Posted December 14, 2009 Members Report Posted December 14, 2009 I have been using eco flow with so-so results. I want to try Angelus dyes based on this forum saying how good it is. I went to order some from turtlefeathers and saw that they strongly recommend a preparer deglazer. What is this and is it really needed? Also do you guys who se Angelus dilute it with anything or do you use it right from the bottle. Also are you all dipping or applying with wool daubers? thanks Quote
Members Rawhide Posted December 14, 2009 Members Report Posted December 14, 2009 I use Angelus dyes and I don't use the deglazer. I dilute the colors with Fiebings Dye Reducer. I usually apply with dye brushes. I never dye with daubers. If you make holsters you might use dipping, but I don't make holsters, so I can't really comment much there. Quote
Members rccolt45 Posted December 14, 2009 Author Members Report Posted December 14, 2009 Thanks for the quick reply. How much reducer do you use and what does it do? Quote
Members Rawhide Posted December 15, 2009 Members Report Posted December 15, 2009 Depends on the color I'm after. All it does is dilute the mix and reduce the intensity of the color. For instance if I want a light blue, I mix a heavy ratio of reducer with a little blue dye. I don't pre determine the ratios, i just mix until I have the color I want. Quote
Members CitizenKate Posted December 15, 2009 Members Report Posted December 15, 2009 The Angelus dyes are very intense. A little of it goes a long way, so I rarely apply it full-strength. I dilute mine with just straight denatured alcohol, which works the same as any of the "reducers", except it's a lot cheaper. You can get a gallon of the denatured alcohol for just a little more than you pay for a 4oz bottle of the reducer. Kate Quote
Members rccolt45 Posted December 16, 2009 Author Members Report Posted December 16, 2009 Thanks for the good info guys!!! Quote
