Members Idahotim Posted January 2, 2010 Members Report Posted January 2, 2010 Howdy folks, I am a rank newbie to leather work but wanted to try to make a holster. I watched / read most everything I could find on the web on the subject and began.... When I dipped the holster into very warm water to wet form it, it shrank and curled up and is apparently ruined! It is hard as a rock. Is there anyway to salvage it? What went wrong? Here are a few facts about my methods: 1) I used leather I have had for a few years, maybe many years! 2) I warmed the water to 140 degrees and added a couple drops of dish soap. 3) I held the holster under until bubbles quit (about 15 seconds) Thanks in advance for your response and aid. Quote
Members TTcustom Posted January 2, 2010 Members Report Posted January 2, 2010 Any pictures of the holster in question? I don't case leather at any particular temp. generally whatever tap temp. is works for me so I don't have the same experience you have had with the curling shrinkage etc... I am sure someone has an answer but maybe you should go get some new Veg tan tooling leather and try again fresh. Good luck. Quote I am fifty years old and I have always lived in freedom; let me end my life free; when I am dead let this be said of me: 'He belonged to no school, to no institution, to no academy, least of all to any régime except the régime of liberty.' "What we need is more cowbell!"
leatherman1457 Posted January 2, 2010 Report Posted January 2, 2010 (edited) the first mistake you made was by submerging it in hot water. what you did was to do something called "cuir boulli' whern you submerge leather in hot water you harden the leather. You can not fix it . You have to get another piece of leather and start over. I use regular tap water with just the cold water on . or you can use a spray bottle and spray it and then put it in a plastic bag to case the leather. I do not use soap. if you do wish to add something to the water to soften up the leather use lexol. another problem was the leather. How many years have you had it and how was it stored. If it was stored when the sun can get to it ,even with out hitting it directly will harden the leather. you broke all the rules on casing ands storing leather. the only reason I know is because I did the same thing when I was a newbie.If you have some of the leather left you could spray some lexol and water on it and put it in a trash bag for a day and see if that helps to make it soft. If it does then you can precede from there. Just use cold tap water to case with .Do not use warm or hot water unless you are making armor. that is what you made with the old leather you started with the holster Edited January 2, 2010 by leatherman1457 Quote If you can conceive it, you can achieve it. visit my web site www.leathertools4u.com "Great minds discuss ideas; average minds discuss events; small minds discuss people." ~ Eleanor Roosevelt
Ambassador Luke Hatley Posted January 2, 2010 Ambassador Report Posted January 2, 2010 use cold water..........next time........ Quote Luke
Members azrider Posted January 2, 2010 Members Report Posted January 2, 2010 Disclaimer- I know nothing about holsters, and have done very little wet forming. My only thought is that since you may have to pitch this one anyways, why not try soaking in cold water until the bubbles disapear, and then shaping it over something until it dries? If nothing else, look at it as a learning experience. Quote Drygulch Leatherworks- Baldwin City, Kansas www.drygulchleather.com
Members Idahotim Posted January 3, 2010 Author Members Report Posted January 3, 2010 the first mistake you made was by submerging it in hot water. what you did was to do something called "cuir boulli' whern you submerge leather in hot water you harden the leather. You can not fix it . You have to get another piece of leather and start over. I use regular tap water with just the cold water on . or you can use a spray bottle and spray it and then put it in a plastic bag to case the leather. I do not use soap. if you do wish to add something to the water to soften up the leather use lexol. another problem was the leather. How many years have you had it and how was it stored. If it was stored when the sun can get to it ,even with out hitting it directly will harden the leather. you broke all the rules on casing ands storing leather. the only reason I know is because I did the same thing when I was a newbie.If you have some of the leather left you could spray some lexol and water on it and put it in a trash bag for a day and see if that helps to make it soft. If it does then you can precede from there. Just use cold tap water to case with .Do not use warm or hot water unless you are making armor. that is what you made with the old leather you started with the holster The leather was not exposed to sunlight, it was in duffel bags in a closet. I suspect my water at 140 degrees was way to hot. The two drops of dish soap was suggested in a tutorial at another site. The leather hardened and twisted while still under water. I have soaked it in cold water most of the day. It has softened a little but is still very hard in spots and still twisted. I am going to start rubbing nexol into it and see it that helps..... If not I will have to find someone with a little bitty automatic possibly with a bent barrel who needs a holster. Quote
Members Idahotim Posted January 3, 2010 Author Members Report Posted January 3, 2010 use cold water..........next time........ That much I have learned... I wanted it to be really soft so I tried the warm water as described elsewhere, but that didn't turn out well. I have softened up old saddles and tack but those were usually dried out after being wet or neglected. This holster has acted very strangely the compared to other leather I have worked with. Quote
Members Idahotim Posted January 3, 2010 Author Members Report Posted January 3, 2010 Disclaimer- I know nothing about holsters, and have done very little wet forming. My only thought is that since you may have to pitch this one anyways, why not try soaking in cold water until the bubbles disapear, and then shaping it over something until it dries? If nothing else, look at it as a learning experience. I am trying that now. If I can get it soft again. Any thoughts on what to use on the leather??? Nexol? Neetsfoot Oil? Saddlesoap??? Suggestions are welcomed! Quote
Members azrider Posted January 3, 2010 Members Report Posted January 3, 2010 If not I will have to find someone with a little bitty automatic possibly with a bent barrel who needs a holster. That's the spirit! I have had good luck with both my leather work, and on dry tack when I lived in Arizona with Olive Oil. Sound like you are doing the kind of things I would try to save it. Good luck. Quote Drygulch Leatherworks- Baldwin City, Kansas www.drygulchleather.com
Contributing Member TwinOaks Posted January 3, 2010 Contributing Member Report Posted January 3, 2010 Save all your Lexol, oil, and other conditioners, pour out the water it's soaking in and use the container for something else. This piece is ruined. When the leather acts like that, you've either cooked it or burnt it- there is no 'fixing' it. Even if you can soften it, the leather has been damaged to the point that you can not reform it. What you can do with it is let it air dry and hang it over the stove or workbench as a reminder of what can go wrong....perhaps put it in a shadow box on a wall and call it "modern art". Sorry to be the bearer of bad news. Quote Mike DeLoach Esse Quam Videri (Be rather than Seem) "Don't learn the tricks of the trade.....Learn the trade." "Teach what you know......Learn what you don't." LEATHER ARTISAN'S DIGITAL GUILD on Facebook.
