Members indypbear Posted January 12, 2008 Members Report Posted January 12, 2008 Chuck, Now that has been said my suggestion (if you wnat them) is take a leaf and flower design on scrap and work on the "thumb print" on the flower and leaf and undercut beveler in the loops of each to lift them more. The thumb print can be restruck once with the round heel only tipping it to deepen the impressions and they will jump off of the piece. The pattern flow is good as is the background. Keep the background depth as consistant as possible. Strop your swivel knife alot during the decorative cuts and they will be smoother in time. I hope that is constructive and not hurtful. You're are doing a great job. Keep up the work. You'll rival Chan Geer soon. Happy Toolin'. Indy Quote
Members Chuck Posted January 12, 2008 Author Members Report Posted January 12, 2008 Chuck, Now that has been said my suggestion (if you wnat them) is take a leaf and flower design on scrap and work on the "thumb print" on the flower and leaf and undercut beveler in the loops of each to lift them more. The thumb print can be restruck once with the round heel only tipping it to deepen the impressions and they will jump off of the piece. The pattern flow is good as is the background. Keep the background depth as consistant as possible. Strop your swivel knife alot during the decorative cuts and they will be smoother in time. I hope that is constructive and not hurtful. You're are doing a great job. Keep up the work. You'll rival Chan Geer soon. Happy Toolin'. Indy Indy Thanks for the tips, This piece of leather was only about 3 or 4 onces and a little thin to get too heavy with the undercut bevelers which I used first. I thought about going back and using them afterbeveling but on a scrap piece I was cutting through the leather. I agree that my finish cuts need improvement, and I am working on that. I will try for deeper thumbprints. Again thanks for the tips. Chuck Quote
Members indypbear Posted January 12, 2008 Members Report Posted January 12, 2008 Indy Thanks for the tips, This piece of leather was only about 3 or 4 onces and a little thin to get too heavy with the undercut bevelers which I used first. I thought about going back and using them afterbeveling but on a scrap piece I was cutting through the leather. I agree that my finish cuts need improvement, and I am working on that. I will try for deeper thumbprints. Again thanks for the tips. Chuck Chuck, just strike it in and then tip it back to the heel and strike it again. See what that will do. In regards to the undercut bevelers 3-4 oz is the thinest that I would go using slick artboard or shelfpaper and lift gently when you undercut it. It lifts even that thin of piece. You'll surprise yourself with the results. Indy Quote
gtwister09 Posted January 12, 2008 Report Posted January 12, 2008 Chuck, just strike it in and then tip it back to the heel and strike it again. See what that will do. In regards to the undercut bevelers 3-4 oz is the thinest that I would go using slick artboard or shelfpaper and lift gently when you undercut it. It lifts even that thin of piece. You'll surprise yourself with the results.Indy Chuck, I agree about the artboard. It will surprise you. The artboard will give you some more depth on the beveling and background. I would also consider smaller mule feet, backgrounding and definitely smaller veiners. I'm not sure that I would have chosen a checkered shader for the flowers but that is a preference. However, I would also thin the width of these shaders down as well (especially for the flowers). Study the width of actual Sheridan shaders and you will see that they are thinner. Others have already discussed the decorative cuts. On decorative cuts try not to cut across or into the flower center. Now the rope....that combination looks pretty good. I have a beveler modified to do that but it's great to know that Barry has one that comes fit to order (less work that way). Keep up the work! Smaller designs always present their own set of problems as you already stated and know. Regards, Ben Quote
David Posted January 12, 2008 Report Posted January 12, 2008 Chuck, I know you told us in a previous post, what is the scale of these saddles? and also how many of them have you done already? Dave Quote
Members Chuck Posted January 12, 2008 Author Members Report Posted January 12, 2008 Chuck, just strike it in and then tip it back to the heel and strike it again. See what that will do. In regards to the undercut bevelers 3-4 oz is the thinest that I would go using slick artboard or shelfpaper and lift gently when you undercut it. It lifts even that thin of piece. You'll surprise yourself with the results.Indy The artboard is new to me will sure give it a try. I generally use around 8oz leather for the fenders and somewhat lighter for the rear jockeys and etc, this was just to see if I could get depth on the light leather. I will also try the two hit method with the tilt. Thanks Chuck Quote
Members Chuck Posted January 12, 2008 Author Members Report Posted January 12, 2008 Chuck,I agree about the artboard. It will surprise you. The artboard will give you some more depth on the beveling and background. I would also consider smaller mule feet, backgrounding and definitely smaller veiners. I'm not sure that I would have chosen a checkered shader for the flowers but that is a preference. However, I would also thin the width of these shaders down as well (especially for the flowers). Study the width of actual Sheridan shaders and you will see that they are thinner. Others have already discussed the decorative cuts. On decorative cuts try not to cut across or into the flower center. Now the rope....that combination looks pretty good. I have a beveler modified to do that but it's great to know that Barry has one that comes fit to order (less work that way). Keep up the work! Smaller designs always present their own set of problems as you already stated and know. Regards, Ben Ben, Since I did that fender I received a #0 and a #1 vertical lined thumbprint from Barry and I am using them ( take a look at the flowers in my other post of the checkbook cover), I also have the smaller of Barry's continues left and right curve mulefeet coming as I certinally agree with you about the size of the imprints. Will Keep working at it, Thanks for the Help. Chuck Quote
Members Chuck Posted January 12, 2008 Author Members Report Posted January 12, 2008 Chuck,I know you told us in a previous post, what is the scale of these saddles? and also how many of them have you done already? Dave Dave the scale is 1/2, the saddle s measure about 14 inches long. I have one that is basket stamped that I made to adjust my patterns, I am tearing it back down to learn from. Chuck Quote
gtwister09 Posted January 12, 2008 Report Posted January 12, 2008 Ben, Since I did that fender I received a #0 and a #1 vertical lined thumbprint from Barry and I am using them ( take a look at the flowers in my other post of the checkbook cover), I also have the smaller of Barry's continues left and right curve mulefeet coming as I certinally agree with you about the size of the imprints. Will Keep working at it, Thanks for the Help. Chuck Chuck, Cool on the tools. As always the right tool for the right job. Regards, Ben Quote
