BearMan Posted February 15, 2010 Report Posted February 15, 2010 Hi Everybody, It's been a little while since I've posted. Just wanted to give an update on a couple things. A couple months ago, I installed a new stamping block heater. My old one lasted about 10 years. What I use is a Water Bed heater, with a thermostat. I was able to find one almost exactly the same size as my block. The way I made my bench, the middle of my stone is open, only the front & back edge, are supported. That way, it makes it easy, to install the heater. It's basically just held up against the stone with a piece of plywood. It takes about 45 min, to an hour to heat the stone from about 50 deg. up to about 80 deg. Makes for some very comfortable tooling. Secondly, yesterday, I bought a "Full Spectrum" desk light, for my tooling bench. I never knew, just how much one of those helps!! If you don't have one,,, GET ONE!! I'm headed down, to get another, for my coloring bench. & maybe even a spare. The colors, & definition, in every situation, just Pops!! Now that I'm actually able to see,,, I'm sure my tooling will get better. If there is such a thing as a "Must Have" list, both of these should be on it. I hope this helps,,, they really have helped me. Take Care,,, Happy Tooling,, Ed the"BearMan" Quote Ed the"BearMan" polarb1717@aol.com Beary: BearMauls@yahoo.com http://tinyurl.com/BearMauls "The Best tooling mauls available today!"
Members westtxcowboy1979 Posted February 15, 2010 Members Report Posted February 15, 2010 On 2/15/2010 at 4:51 PM, BearMan said: Hi Everybody, It's been a little while since I've posted. Just wanted to give an update on a couple things. A couple months ago, I installed a new stamping block heater. My old one lasted about 10 years. What I use is a Water Bed heater, with a thermostat. I was able to find one almost exactly the same size as my block. The way I made my bench, the middle of my stone is open, only the front & back edge, are supported. That way, it makes it easy, to install the heater. It's basically just held up against the stone with a piece of plywood. It takes about 45 min, to an hour to heat the stone from about 50 deg. up to about 80 deg. Makes for some very comfortable tooling. Secondly, yesterday, I bought a "Full Spectrum" desk light, for my tooling bench. I never knew, just how much one of those helps!! If you don't have one,,, GET ONE!! I'm headed down, to get another, for my coloring bench. & maybe even a spare. The colors, & definition, in every situation, just Pops!! Now that I'm actually able to see,,, I'm sure my tooling will get better. If there is such a thing as a "Must Have" list, both of these should be on it. I hope this helps,,, they really have helped me. Take Care,,, Happy Tooling,, Ed the"BearMan" Where did you get the Full Spectrum lights? Quote
BearMan Posted February 15, 2010 Author Report Posted February 15, 2010 Hi, I got the lights at Big Lots, They are on sale today, fot $15.00 for the desk lamps, & $19.99 for the floor lamps. Quote Ed the"BearMan" polarb1717@aol.com Beary: BearMauls@yahoo.com http://tinyurl.com/BearMauls "The Best tooling mauls available today!"
King's X Posted February 15, 2010 Report Posted February 15, 2010 Pictures, pictures! Quote Greetings from Central Texas! The Grain Side Up blog #TheGrainSideUp
Members whinewine Posted February 15, 2010 Members Report Posted February 15, 2010 On 2/15/2010 at 7:18 PM, BearMan said: Hi, I got the lights at Big Lots, They are on sale today, fot $15.00 for the desk lamps, & $19.99 for the floor lamps. That's a very good price, Ed. I have both Ottlite & Verilux, both I got on sale- the Verilux from Ollies Outlet & Ottlight from Michaels. russ Quote
