Hey guys need some help, a buddy at work has a old bellows kind of like the ones in this link http://www.fireplacescreenshop.com/fireplace-screen-accessories-bellows.html?utm_source=google&utm_medium=cpc&utm_term=bellows&utm_content=Bellows&utm_campaign=Fireplace+Screen+Shop The bellows itself is from around the 1920's - 1930's, sorry dont have a pic of it as cant take pics at where I work. It belonged to his dad I think and was used to fan the fire to say for making sand casts. What I need some help with is what kind of leather did these old guys use? I took a small piece that I will post pics of tonight when I get home. It seems to be about 2oz, reddish brown allmost a brick red color. The stuff is pretty much completely rotten so its hard to tell what it use to be but allmost seems like really thin latigo or something (Im probably way off). Any ideas or suggestions welcome.
Found a pic that is as close as Ive scene so far.
Edited by MADMAX22
Here is a pic of the piece I took off of it. I know not much to go off of but the best I could do.
I think the old ones were made with veg tan leather, but good luck finding something thin and flexible. You might try book binding leather. I just use the thinnest chap leather I can find.
Good luck,
Kevin
Thanks guys. Was scouring the web last night looking for info but didnt come up with anything. Found all kinds of stuff about the wood, history, operation and such but when it comes to the leather they always just say leather.
I will keep the vegtan in mind and maybe look for some calf or something similer then try and find a dye mix to come close to what the color use to be.
I have another question. Does that reddish brown color come from the leather rotting or was it probably originally a dyed leather? Some of the old pictures I have scene almost seem to suggest a nice oiled natural vegtan without dye or a really light coloring. Seems maybe the leather darkens alot as it drys up and rotts but I dont have much experience in helping out with restoration work.
Not sure, but the color could come from: 1] use, or 2] aging/sun struck, or 3] treated with oil or fats- or all of the above... Regardless, vegtan goat has very tight grain, very flexible... Even softer & more flexible would be vegtan sheep. You can get it from about 2oz - 3-1/2 oz. I'd call Siegel's- they could certainly give a good recommendation as what would be better to use. I'd also suggest you treat it with something- Skidmore's, Pecards, Aussie- whatever. Really, what you want to do with it depends on what you plan for the bellows. If it is to be a truly museum restoration, then you should contact a museum conservator to get recommendations from him/her; if you just want it to be a functional, working piece, approximating the original material, then you have a greater flexibility when it comes to the restoration.
Sounds like red rot.
http://en.wikipedia....t_%28leather%29
Barra
Thanks a bunch, that is exactly what this leather seems to have happened to it. Matches that description to the tee.
Whinewine thanks also, Ill look into some of that stuff. Its primarily a sentimental value since it belonged to this guys grandfather and father and it will probably be somewhat of an ornament once it is restored, however that being said if we are gonna go thru all the work to get back to a good order I want it to be as functional or close to it as it was when the thing was inservice.
Once again really appreciate the help this should get us well on our way.
I've restored many sets of fire bellows, and in my experience it's essential that you use veg-tanned leather. One of the final stages of restoration is to draw the leather into the 'concertina' shape around the internal springs, and for this to work, the leather needs to be thoroughly wetted. Chrome-tanned leather is very difficult to soak, and does not tend to hold its shape when dried in the same way that veg-tanned leather does.
I use 1-1½mm natural calf or 2mm goatskin, depending on the size of the bellows, and I dye it before fitting to the bellows.
If it's any help, I've attached a pdf of the various stages I go through in bellows restorations.
Terry
Bellows3.pdf
Bellows3.pdf
When everyone is somebody, then no one's anybody
