Thanks, Noah. I got one more question for you. What does heating the brass parts do? Won't the tarnish remain without it?
Thanks, this is a technique I am definitely going to use.
  • Replies 20
  • Created
  • Last Reply
Top Posters In This Topic
Hey, thanks, Noah! I've been looking for a way to do this!
Kate
You're welcome, I'm glad I could help!
The tarnish will remain, but the tarnish is blotchy, and heating the brass parts darkens them beneath the tarnish--the quenching in mineral oil is something I did because water made some of the tarnish flake off. It certainly isn't something you NEED to do, it's just what I did. Play around with it, and I certainly hope to see lots of antiqued brass hardware from everyone showing up in the Show Off forum! :)
~Noah
Website: Wasteland Leatherwork
Collaboration Projects: The Wasteland Crow Project
I've had better results with ammonia also. Ammonia gives the brass a more natural patina but will blacken the longer you leave it in the fumes. A dremel with a wire brush attachment cleans the part up nicely leaving behind a piece that looks like it's a 100 years old with small pits in the metal and all.
Solid brass works best but this is also a good way to tell if a part someone sold you as solid brass is really solid brass or just brass plated metal. Some parts are actually solid brass with a nickle plate on them and the ammonia will eat the nickle or gold or brass, just about any plating away.
I would like to add a few things after doing some more playing around with this due to the questions I received from Mr. Banwell.
The tarnish from the vinegar fumes WILL rub off while it is wet unless you heat the brass. Some of the patina will stay, but the heat has a similar effect to Parkerizing in that it strengthens the patina.
Also, some brass will take longer to tarnish hanging over vinegar--for instance, those clips did not have to stay in as long as some dee-rings I just finished. I suspect it has something to do with the alloy.
As others have said, ammonia will definitely give you good results, but I have pets and one of them has a very sensitive respiratory system, so ammonia is not an option in my household. This is a safe alternative, not the be-all-end-all method :)
~Noah
While those methods will work, if you need something quicker you can use Ferric Chloride (circuit board etchant,available from Radio Shack)and water solution.I use it on steels, brass,and copper when doing period pieces.Dave
I tried this method using vinegar and it worked splendidly. First I put all my parts including tiny brass screws in a rock tumbler overnight with sand to remove the finish. After 2 hours in the vinegar fumes the parts were a nice dark brown. A little uneven, but I don't mind that at all for the look that I'm after. Before hearing of the fume technique I had brushed on vinegar and let dry, several coats. Also I had spritzed the parts with a spray bottle. Neither of those methods worked nearly as well as the fuming, so Noah, again I thank you for posting this.
Another very old trick is is to lightly scratch the hardware up, then take three or four family sized caffinated tea bags in to a small post of boiling water. Now there are to different looks you can go for. 1) looks like forged aged brass. to do that simply drop the hardware in the pot. leave it for about 5 minutes and check to see if it the color you are wanting. continue this until you achieve the patina you want. The other way is to just age the metal by putting them in a metal screen type of colander and suspend the item in the boiling tea. Remember to leave the items in the tea for at least 10 minutes after cooling. (of course you can check through out the whole process to see if you have achieved the color you like. This works on all metals.
$500 DOLLAR BOOTS A $5000 DOLLAR HORSE AND 50 HOURS IN A SADDLE DON'T MAKE YOU A COWBOY.
THE SMALLER YOUR SPUR ROWELS THE MORE AGGRESSIVE THEY ARE.
FUNNIEST THING I HAVE SEEN THIS SPRING WAS A GUY THAT ROPED A BULL ON A FOUR WHEELER. WHEN THE AMBULANCE GOT THERE THE EMT LOOKED AT HIM STRAIGHT FACED AND SAID, " MAN DON'T YOU KNOW THATS WHY WE USE HORSES"
Great! I'm glad it worked well for you!
Really? How durable is that finish, though? I know that heat will darken brass, but I didn't think tea would be able to stain it.
~Noah
~Noah
Works great, my granddad taught me how to do it and I have just all ways done it that way. just remember to lightly brush the hardware with a soft wire brush.
  • 7 months later...
I found something called Patina Gel. It's stabilized liver of sulfur. It works on silver, copper, bronze and brass.
http://www.cooltools.us/Cool-Tools-Liver-of-Sulfur-in-Gel-Form-p/pol-800parent.htm?1=1&CartID=0
I've only tested it out so far, to darken copper rivets.
The heating and quenching in oil is interesting. I've found that any patina method I tried tended to rub off easily. The gel gave me the best results. I'll have to try heating and oil quenching with it.
