Members DomsLeather Posted May 5, 2010 Members Report Posted May 5, 2010 I had a bit of trouble setting tandy rivets when I started out ....the main problem for me was the lower cap anvil ...one its really made for setting snaps I feel...and is used to set rivets but to me its not optimal way of doing it...I had 2 hand setters....so i had a washer welded around one....and slip in in a printle hole in my bench anvil...it gives me a solid base to start...and also can see your hammering straight on the rivet also.... I use small taps with a mallet and can feel the rivet setting...when it tightens up to where i want it...I leave it I may look at it once or twice as its tightening up...I have not had any trouble with them pulling out....some others here have...I have pulled with all i have before and cant get them apart if set right. this is my experience will post a pic of my setup also. Quote
Members Henge Posted May 15, 2010 Author Members Report Posted May 15, 2010 I had a bit of trouble setting tandy rivets when I started out ....the main problem for me was the lower cap anvil ...one its really made for setting snaps I feel...and is used to set rivets but to me its not optimal way of doing it...I had 2 hand setters....so i had a washer welded around one....and slip in in a printle hole in my bench anvil...it gives me a solid base to start...and also can see your hammering straight on the rivet also.... I use small taps with a mallet and can feel the rivet setting...when it tightens up to where i want it...I leave it I may look at it once or twice as its tightening up...I have not had any trouble with them pulling out....some others here have...I have pulled with all i have before and cant get them apart if set right. this is my experience will post a pic of my setup also. I've definitely felt the tandy rivets set. But they still pull out fairly quickly with normal use of the finished piece. Thank you so much for your reply! Quote
