Members rgerbitz Posted June 10, 2010 Members Report Posted June 10, 2010 I have only done this a two times. But I started with a healthy hand full of red onion peels and a 2 quart sauce pan 3/4's full. Boiled the liv'in ship out of it then strained through a wire strainer. The longer the rawhide sits in it the darker the color gets. The second time I did it and used a bigger pan with more water. I ended up having to boil off some of the water to get it as dark as I thought it should be. There are my two experiences and the extent of my knowledge on the subject. Pretty impressive, I know. Rob Quote http://gerbitzquarterhorses.com/
Members entiendo Posted June 10, 2010 Author Members Report Posted June 10, 2010 Oh what fun! I haven't been able to find out how to dye with natural ingredients yet. I don't think I can just let the roo sit in the water...but I think roo would absorb the dye better than rawhide. It would seem the roo would also fade more easily. I'll keep looking though. Thanks for list of things I can use to change the color of my roo! This also has me inspired to try it with rawhide. That would be fun. You don't see colored rawhide very often. Quote
Members 8thsinner Posted June 10, 2010 Members Report Posted June 10, 2010 If you find out some good sources for colour fasting the dyes in raw or roo, let us now, I found that the alder bark, used to be rubbed straight into the leather (dry) about half a dozen times leaving to sit over night. Quote Doing the right thing is bleeding for the cause. Website Facebook
Members wantmorelandandcattle Posted June 12, 2010 Members Report Posted June 12, 2010 Here's a pretty good link to get you started. (http://www.pioneerthinking.com/naturaldyes.html) I've dyed hides in coffee and onions skins quit a bit. I've used yellow and red onions and mixed them too. In stead of buying all the onions, i just ask the local store if I can bag up all the peelings that are in the bottom of the onion bin. After you tell them what its for, they stop looking at you funny and let you take what you want. No charge as it is less mess for them to clean up. You can do the same at the local coffee shop, ask them for the old coffee grounds or hit up Starbucks, they used to bag it and give it away free, I think they charge now (good fertilizer for roses). I usually set the dye by rinsing the hide several times (until the water comes out clear) then give it a day or two soaking in vinegar and that seems to work pretty good. Some people have told me they have better luck not rinsing the hide, they go straight to the setting process. I have used some leaves and petals off of various plants that were on the ranches I worked on too. I could get the dye to set, but never got any colors that I liked, I wasted a lot of hides, so I quit experimenting. I got a hide off a colt one time that had gotten into loco weed and beat himself up pretty bad thrashing around and throwing himself on the ground one day until he died. When I skinned him, you could see where the blood started to collect in the hide as a bruise. Those places that had the bruise had a really neat color to them. I always wanted to figure out a way to stain hides with blood, I've heard of it being done, but I can't seem to find/figure out a good process. Like always, make sure your hides are fleshed really good, or you will end up with different hues of the same color when you dye. Some of which can be very different from each other. Hope that helps a little bit! Good luck! Jake Hogan Wantmore Land and Cattle Quote Thank you, Jake Hogan wantmorelandandcattle.com Facebook
Members entiendo Posted June 12, 2010 Author Members Report Posted June 12, 2010 I do have one question, is it good for the leather to sit in liquid that long? What do you use to soften it back up? Oh, well I guess that's 2 questions. thanks wantmorlandandcattle...that was all very helpful. Quote
Members wantmorelandandcattle Posted June 14, 2010 Members Report Posted June 14, 2010 Well, your right, you probably shouldn't leave leather in liquid that long, it will get really moldy and rot. I think you best bet would be to dip and dry the hide as many times as needed to get the depth of color your looking for and then condition the hide. You might try contacting someone who restores old saddles for museums and collectors, they may tell you some trade secrets on reconditioning. I guess I should have specified hat most of what I do is rawhide. The basics of dyeing are really the same though. You need to dye and then set. I have done a little leather dyeing and figured out how to dye and set, but I never got a very thorough color, it was really spotty, like tie dye! I'll do a little research and see if I can find some good info to post. I don't know if you've ever seen them, (they're a bit obscure) the Firefox books. They may have them at your local library. My parents had a bunch of them and I've picked up a few throughout the years. If I remember right, there was one that talked about tanning and dyeing. There was an article in that same one talking about makeing a dipper out of a gourd and I think they made a banjo too; that may help you find the right one. They're neat books anyway of you never seen them! Take care, Jake Quote Thank you, Jake Hogan wantmorelandandcattle.com Facebook
Members entiendo Posted June 14, 2010 Author Members Report Posted June 14, 2010 (edited) Thank YOU <img class="bbc_emoticon" alt="" src="http://leatherworker.net/forum/public/style_emoticons/default/You_Rock_Emoticon.gif"> I'll see if I can find the books. You know we have a saddle maker not to far from here. He's a little grumpy in my experience but it still may be worth dropping by and seeing him. Maybe he will share. there is something screwy with the edit option on this board, I have no idea why I keep get weird command when I use it. Edited June 14, 2010 by entiendo Quote
Members wantmorelandandcattle Posted June 15, 2010 Members Report Posted June 15, 2010 I had a few minutes, so I thought I would send you these links. I find these books interesting, most people I know that like "the old ways" of doing things like them. The books are about older generations of people from the Appalachians and how they lived (starting in the 70's). I thought you (or others on here) might find them interesting at the least. Firefox 3 has the articles on leather tanning, I couldn't find any specifics on dyeing although I didn't read through them again. You may find some articles on dyeing and setting clothing if nothing else, but I have no idea which book that would be in, there are 12 in all. So here's the links and a short blurb on what they are: Wikipedia page on The Firefox Books - http://en.wikipedia.org/wiki/Foxfire_books The Firefox organizations website - http://www.foxfire.org/ Book reader and download (I have never used this site). Just search "The Firefox Book" and you'll get all the books. - http://www.scribd.com/ Specifically book 3 - http://www.scribd.com/doc/8961322/Foxfire-Three That ought to keep you busy! Enjoy. Jake Hogan Wantmore Land and Cattle Quote Thank you, Jake Hogan wantmorelandandcattle.com Facebook
Members entiendo Posted June 15, 2010 Author Members Report Posted June 15, 2010 Thanks a lot! I'll go check them all out as soon as I get a chance. I appreciate all the effort! Quote
Members Texomawhips Posted June 28, 2010 Members Report Posted June 28, 2010 I do have one question, is it good for the leather to sit in liquid that long? What do you use to soften it back up? Oh, well I guess that's 2 questions. thanks wantmorlandandcattle...that was all very helpful. The leather will be very stiff once it dries completely, but a good leather conditioner or plaiting soap will bring it back. Quote Jim http://www.texomawhips.com
