jeff1040
Tippman N
looking for feed back on the tippmann clicker how do you rate on a scale 1- 10
I've had the opportunity to use both the 7-ton and 15-ton.
I would rate the 7-ton as a 4: struggled to cut through 6/7 oz leather. Easier to move around than the 15-ton.
I would rate the 15-ton as a 9: has cut through anything I've put under it. Very difficult to move around - ended up using an engine lift on each occasion.
If you are talking about the small portable, I've tried it and it is limited. If you are looking for a portable clicker, and don't need a clicker to turn out a high volume of items aday, I built the clicker that Texas die sells. She told me how to make it and it works great. It cost me about $200 to make and I can cut through any leather out there. I use it daily. Mike
Sorry, getting senior moments, I was thinking of the portable Weaver. Ignore me.
