Members particle Posted June 28, 2010 Members Report Posted June 28, 2010 I recently decided to buy the stirrup plate accessory for my Tippmann Boss. I won't get into the "why", aside from saying it's to make sewing an "Avenger" style holster a little easier. So, I pulled the attachment out of the bag, fondled it a bit, noticed it had quite a few sharp edges on it, then went ahead and installed it. I figured those sharp edges must not be a problem, or Tippmann would have already addressed it in quality control. First time stitching with the new stirrup plate installed, I noticed the thread was fraying. Wondered if maybe the added height tweaked the tension or something, but soon found out it was those darn sharp edges on the bottom side of the plate that was fraying the thread as it was pulled up from the bobbin. Yanked it off, polished it up with my dremel, then back to work. Fraying was gone. On to my first holster with it installed... More sharp edges are causing problems now!! Turns out pretty much the entire black part of the accessory needs to be sanded down and buffed up - those stupid sharp edges are scraping the crap out of my work! Darn you Tippmann - at least run them through a sand blaster with some aggressive media or something before sending them off for final paint!! Quote Eric Adamswww.adamsleatherworks.com | Facebook | YouTube | Instagram
Members oldtimer Posted June 28, 2010 Members Report Posted June 28, 2010 On 6/28/2010 at 1:42 PM, particle said: I recently decided to buy the stirrup plate accessory for my Tippmann Boss. I won't get into the "why", aside from saying it's to make sewing an "Avenger" style holster a little easier. So, I pulled the attachment out of the bag, fondled it a bit, noticed it had quite a few sharp edges on it, then went ahead and installed it. I figured those sharp edges must not be a problem, or Tippmann would have already addressed it in quality control. First time stitching with the new stirrup plate installed, I noticed the thread was fraying. Wondered if maybe the added height tweaked the tension or something, but soon found out it was those darn sharp edges on the bottom side of the plate that was fraying the thread as it was pulled up from the bobbin. Yanked it off, polished it up with my dremel, then back to work. Fraying was gone. On to my first holster with it installed... More sharp edges are causing problems now!! Turns out pretty much the entire black part of the accessory needs to be sanded down and buffed up - those stupid sharp edges are scraping the crap out of my work! Darn you Tippmann - at least run them through a sand blaster with some aggressive media or something before sending them off for final paint!! Tippmann quality control ?????? Quote "The gun fight at the O.K. corral was actually started by two saddlemakers sitting around a bottle of whiskey talking about saddle fitting"...
Moderator Johanna Posted June 28, 2010 Moderator Report Posted June 28, 2010 Call Tippmann and explain the problem. Tippmann is known for outstanding customer service, before and after the sale, so I'm sure they will make things right with you. Johanna Quote You cannot depend on your eyes when your imagination is out of focus. - Mark Twain
Members oldtimer Posted June 29, 2010 Members Report Posted June 29, 2010 On 6/28/2010 at 8:01 PM, Johanna said: Call Tippmann and explain the problem. Tippmann is known for outstanding customer service, before and after the sale, so I'm sure they will make things right with you. Johanna My experience is that their "outstanding customer service" does not include Europe! Quote "The gun fight at the O.K. corral was actually started by two saddlemakers sitting around a bottle of whiskey talking about saddle fitting"...
