Members Hooligan Posted June 29, 2010 Members Report Posted June 29, 2010 When building tugs for breast collars (including tripping collars and martingales), I've seen rivets used to secure the buckle and loops on, and I've also seen fancy Chicago screws used... Why would you use one or the other? Is one stronger than the other? I guess you'd use Chicago screws incase the buckle broke or you lost a loop...? But isn't there a risk of the Chicago screw backing out or no? Anyone care to offer their two cents? Quote
Members NoahL Posted June 29, 2010 Members Report Posted June 29, 2010 When building tugs for breast collars (including tripping collars and martingales), I've seen rivets used to secure the buckle and loops on, and I've also seen fancy Chicago screws used... Why would you use one or the other? Is one stronger than the other? I guess you'd use Chicago screws incase the buckle broke or you lost a loop...? But isn't there a risk of the Chicago screw backing out or no? Anyone care to offer their two cents? I think it's preference, as well as the ability to remove the buckle and loop if necessary. I used Chicago screws on my dog's collar, and I did have problems with them backing out until it occurred to me that I could Loctite them Quote Website: Wasteland Leatherwork Collaboration Projects: The Wasteland Crow Project
Members mulepackin Posted June 29, 2010 Members Report Posted June 29, 2010 I personally think Chicago screws should only be used in applications where you plan on removing or exchanging the secured item frequently. Not for an item that "might" need to be replaced. Quote
dirtclod Posted June 30, 2010 Report Posted June 30, 2010 I sew mine. Quote I'm old enough to know that i don't know everything.
Members Hooligan Posted June 30, 2010 Author Members Report Posted June 30, 2010 Thanks everyone! I never thought of using Loctite on the screws... That would make sense though, as thats what I use on my conchos! HA! Think I'll hum and haw some more on this one... Thanks again for your help! Muchly appreciated! Quote
Ambassador pete Posted June 30, 2010 Ambassador Report Posted June 30, 2010 for a tripping collar and a breast collar under heavy use- I wouldn't use it myself unless I sewed it and riveted it. That's the last thing that I want to worry about. pete Quote
Members joe59 Posted July 1, 2010 Members Report Posted July 1, 2010 Pete and Dirt Clod are right on the money. Sewn or sewn and riveted using a rivet and burr. Also I keep a cheap bottle of nail polish on my bench and in the horse trailer. It works as well as lock Tight and it keeps better and is a lot cheaper. Quote
hidepounder Posted July 1, 2010 Report Posted July 1, 2010 I sew my buckles on and would rivet if I wasn't sewing. I would not use chicago screws in this application. IMHO they are too light and not strong enough for tugs. ESPECIALLY for the center tug! Typically buckles are not changed out on tugs and unless someone specifically requested them I would not use them. Just my opinion, Bobby Quote
Members MikeCahill Posted December 17, 2010 Members Report Posted December 17, 2010 When building tugs for breast collars (including tripping collars and martingales), I've seen rivets used to secure the buckle and loops on, and I've also seen fancy Chicago screws used... Why would you use one or the other? Is one stronger than the other? I guess you'd use Chicago screws incase the buckle broke or you lost a loop...? But isn't there a risk of the Chicago screw backing out or no? Anyone care to offer their two cents? perhaps I've only ever come across cheap Chicago screws but I wouldn't use them anywhere there was likely to be any serious stress as a belt and braces man, I would stitch or rivet and stitch, if something fails, you buy better hardware next time 'cos it won't be the stitching that failed cheers Mike Quote
