Members jeansky Posted July 9, 2010 Members Report Posted July 9, 2010 HI every one, that's my first post. im planning to order a vergez blanchard plough gauge, but is there any web introduce this tool? because i just know it is use to cut a strap accurately. but i don't know to use it and it's very expensive tool compare to others. so i don't want to waste this great tools. can any one help me ? please. thanks Quote
Moderator bruce johnson Posted July 9, 2010 Moderator Report Posted July 9, 2010 I am attaching a few pictures to show I how I run mine. For short straps I hold the tail end in my left hand with the tail coming up over the top of my handle and push. For longer straps off a full length side I run both sides of the cut under the handle. I tension the free end with my left arm and push with the right as I walk along the bench. Quote Bruce Johnson Malachi 4:2 "the windshield's bigger than the mirror, somewhere west of Laramie" - Dave Stamey Vintage Refurbished And Selected New Leather Tools For Sale - www.brucejohnsonleather.com
Members jeansky Posted July 10, 2010 Author Members Report Posted July 10, 2010 Bruce, thank you for your help. i want to know that can the plough gauge be operating on the soft and thin leather, for example thinner than 1.5MM leather? Quote
Moderator bruce johnson Posted July 10, 2010 Moderator Report Posted July 10, 2010 As long as the leather isn't stretchy or too soft, a plough gauge will cut it alright. Quote Bruce Johnson Malachi 4:2 "the windshield's bigger than the mirror, somewhere west of Laramie" - Dave Stamey Vintage Refurbished And Selected New Leather Tools For Sale - www.brucejohnsonleather.com
Members Leatherimages Posted July 10, 2010 Members Report Posted July 10, 2010 (edited) Bruce, thank you for your help. i want to know that can the plough gauge be operating on the soft and thin leather, for example thinner than 1.5MM leather? I can't speak from experience with this cutter, but I have had good results backing thin leathers with a firm paper of some kind, and running it thru strap cutters. Use rubber cement to easy removal. Edited July 10, 2010 by Leatherimages Quote Back to the bench, Paul "When you finally get your wings, don't complain about the wind in your face."
Members jeansky Posted July 10, 2010 Author Members Report Posted July 10, 2010 HI bruce, even that's the new plough gauge, when i use it to cut a thick leather also feel very difficult pull the leather backward and push the plough gauge forward. is the blade not sharp enough? did you try this situation before? thanks Quote
Moderator bruce johnson Posted July 10, 2010 Moderator Report Posted July 10, 2010 With a few exceptions, most cutting tools you buy new are not sharp enough to go right to using. It should cut really easily once you have it sharpened up and stropped. The Vergez Blanchard steel seems to be pretty good. Quote Bruce Johnson Malachi 4:2 "the windshield's bigger than the mirror, somewhere west of Laramie" - Dave Stamey Vintage Refurbished And Selected New Leather Tools For Sale - www.brucejohnsonleather.com
gtwister09 Posted July 10, 2010 Report Posted July 10, 2010 To add to Paul's comment, I have used shelf liner for thin leather every once in a while. I have only had to use this technique a couple of times with chap leather that tended to move a lot when trying to cut fringe. It was a trick that a older saddlemaker/chapmaker showed me more than 30 years ago. Regards, Ben Quote
Members jeansky Posted July 12, 2010 Author Members Report Posted July 12, 2010 (edited) YES, vergez's steel is pretty good. but can i sharpen this blade by myself ? can i use the sharpen stone to sharpen it? just like the attach photo thanks Edited July 12, 2010 by jeansky Quote
Members gesa Posted July 12, 2010 Members Report Posted July 12, 2010 The stone is too coarse to sharpen the blade, it can only be use to shape the blade. I have never used a stone to sharpen my knifes, I am fortunate to use the machine where I work. The right side is fine sandpaper and on the left a felt wheel coverd with green polishing stuff. Important is to polish the blade until it is razor sharp! Greetings Gesa Quote
