Members Deanimator Posted July 28, 2010 Members Report Posted July 28, 2010 (edited) My first piece of leather from Tandy was 5-7oz. The next was 8-10oz. The first was maybe a little light, but worked ok. The second worked, but is probably much thicker than it needs to be. A guy on another forum uses 6-8oz., which I'm thinking of standardizing on. I'm probably going to get myself a piece of good leather in the near future, instead of the remnants I've been using and want to avoid wasting money, by buying what I really need. Also, for the cover that's sewn over the belt clip to hold it in place, what's a good weight? I suspect something lighter than the 5-7oz. that I used for my first IWB. Thanks. Edited July 28, 2010 by Deanimator Quote "When I was young, I looked like Al Capone but I lacked his compassion." - Oscar Levant.
King's X Posted July 28, 2010 Report Posted July 28, 2010 This may or may not help, but I believe I got this off of this site. It is something that will provide you some general guidelines. As for Holsters, I think a 6-8 oz should be plenty once you line it (if your going to). I believe and some may correct me that do this for a living, but you want it to safe and secure. I know when I carried for a living and made my own detective rigs, security was my primary concern as an amatuer maker. Anyways, this helps you out. Good luck. Quote Greetings from Central Texas! The Grain Side Up blog #TheGrainSideUp
Members Deanimator Posted July 28, 2010 Author Members Report Posted July 28, 2010 This may or may not help, but I believe I got this off of this site. It is something that will provide you some general guidelines. As for Holsters, I think a 6-8 oz should be plenty once you line it (if your going to). I believe and some may correct me that do this for a living, but you want it to safe and secure. I know when I carried for a living and made my own detective rigs, security was my primary concern as an amatuer maker. Anyways, this helps you out. Good luck. Thanks. I have no plans for lined holsters, although if somebody actually wanted one, I'd do whatever they were willing to pay for. Quote "When I was young, I looked like Al Capone but I lacked his compassion." - Oscar Levant.
Members gregintenn Posted July 28, 2010 Members Report Posted July 28, 2010 I like 7/8 oz. for most holsters. Once, the store was out of 7/8 oz. and let me have a 9/10 oz. double shoulder for the same price. I used it , but it was really heavy and hard to detail mold. It did make good, durable holsters. Quote
Members Deanimator Posted July 29, 2010 Author Members Report Posted July 29, 2010 I like 7/8 oz. for most holsters. Once, the store was out of 7/8 oz. and let me have a 9/10 oz. double shoulder for the same price. I used it , but it was really heavy and hard to detail mold. It did make good, durable holsters. My Glock 22 holster is 9-10oz. You could use that thing as a brake shoe! Quote "When I was young, I looked like Al Capone but I lacked his compassion." - Oscar Levant.
Members CliffFendley Posted July 30, 2010 Members Report Posted July 30, 2010 I use 8-9 oz for 90% of gun leather and knife sheaths since most of my gun leather is period stuff and is not lined. If it's a lined pouch I will use lighter weights to get 8-10 oz when I'm finished Quote http://www.fendleyknives.com/
hidepounder Posted July 31, 2010 Report Posted July 31, 2010 7/8 oz leather is a pretty good middle of the road weight to use. It is pretty versaltile for a lot of different types of projects. Bobby Quote
Members katsass Posted July 31, 2010 Members Report Posted July 31, 2010 (edited) My first piece of leather from Tandy was 5-7oz. The next was 8-10oz. The first was maybe a little light, but worked ok. The second worked, but is probably much thicker than it needs to be. A guy on another forum uses 6-8oz., which I'm thinking of standardizing on. I'm probably going to get myself a piece of good leather in the near future, instead of the remnants I've been using and want to avoid wasting money, by buying what I really need. Also, for the cover that's sewn over the belt clip to hold it in place, what's a good weight? I suspect something lighter than the 5-7oz. that I used for my first IWB. Thanks. FWIW, I use TWO layers of lighter leather (bonded together so that the inside and outside are both smooth) for almost all of my holsters. Basically, almost all holsters are then lined. You end up doing a bit more stitching, however, I feel (rightly or wrongly) that the final molded holsters are firmer, and retain that rigidity longer, than a single thickness of heavier leather. That said I probably use more 4/5 oz leather (shoulder) than anything else. Mike Edited July 31, 2010 by katsass Quote NOTE TO SELF: Never try to hold a cat and an operating Dust buster at the same time!! At my age I find that I can live without sex..........but not without my glasses. Being old has an advantage.......nobody expects me to do anything in a hurry.
Members Deanimator Posted July 31, 2010 Author Members Report Posted July 31, 2010 FWIW, I use TWO layers of lighter leather (bonded together so that the inside and outside are both smooth) for almost all of my holsters. Basically, almost all holsters are then lined. You end up doing a bit more stitching, however, I feel (rightly or wrongly) that the final molded holsters are firmer, and retain that rigidity longer, than a single thickness of heavier leather. That said I probably use more 4/5 oz leather (shoulder) than anything else. Mike I'm not going to be doing any lined holsters for the foreseeable future, but that's definitely an interesting way to do it. I've never owned a lined holster. Of course the best holsters I've ever BOUGHT were the Don Hume IWBs I use. For my purposes, the ones I'm making now are better, and neither are lined. That doesn't make it a bad idea, just not something that currently justifies the effort, although that could change. When I make an OWB for my 4" S&W Model 29-2, I might consider try that technique just to see how it works. Quote "When I was young, I looked like Al Capone but I lacked his compassion." - Oscar Levant.
Members mdmorgan Posted August 3, 2010 Members Report Posted August 3, 2010 I like 6/7 although I found that some suppliers 6/7 is thinner than others. Quote
