Members Aggiebraider Posted July 29, 2010 Members Report Posted July 29, 2010 Howdy Everyone, So I have always struggled with burying my string ends successfully to where you dont see the cut off end, and it doesnt bunch up as you push it back through. I have tried using an exacto knife and pull the string as tight as I can get it then cut the excess off as close as I can get, so that when its loosened back up it will be hidden, but about all I was able to do was put cut marks in parts I didnt want to. Any advice or tricks on how to attractively bury ends would be greatly appreciated. Thanks, CW Quote
Members entiendo Posted July 29, 2010 Members Report Posted July 29, 2010 Under 3 strings and cut it with a nail clipper. I hope your buttons are nicely rolled and taunt? For second and 3 interweave colors it's a little more tricky. I cut them as close as I can with my clippers and then take my fid and poke the last little bit under and roll again. Quote
Members Aggiebraider Posted July 29, 2010 Author Members Report Posted July 29, 2010 The nail clippers is a good idea, never thought about using those. I do roll everything and tightness is a problem I have but I have trouble not getting things too tight lol. I do go under 3, so maybe its because things are too tight and there isnt anywhere for the ends to move to....I dont know, thanks for the info though! Another thing I am having trouble with my buttons whether to tie them on a mandrel and then transfer them to the piece, or just braid them on the piece. Im having troubles with both ways. If I do them on the mandrel first, I have trouble getting everything lined up just right and centered when I start tightening it up. Alot end up lop sided and not perfectly round. When I just braid them right on the piece, things get too tight and I dont have room to fit the interweaves in. Im really starting to hate putting buttons on things. Does anyone have a good way to judge how much foundation to put down for a button? I made a leash and spliced 12 plait back on itself for the handle and put a tapered turnback button on it and the button turned out nice, but it doesnt completely cover the top of the foundation. I know that this is probably another of the "feel" aspects of plaiting, and with practice I will get better, I just dont want to have to take buttons off 2 or 3 times over the next year to get them right. CW Quote
Members entiendo Posted July 29, 2010 Members Report Posted July 29, 2010 I always braid my buttons directly onto my pieces. I use a fid with each over and under. I did try a mandrel, didn't work so well for me. All that string everywhere. Even so I still go back and tighten the button. That's why I use the center of the hide for buttons, so the buttons can be wicked tight. Course I broke many, many strings on finished buttons before I learned how tight was to tight. As far as how many passes on the foundation...experience. If there is to much showing through I make another pass. Sometimes I try and skimp, that's why I learned how to do the 2nd and 3rd interweave colors...LOL Quote
Members Aggiebraider Posted July 29, 2010 Author Members Report Posted July 29, 2010 The interweaves are all snug and another pass I dont think would help. Its almost like the very top of the foundation is a little too long, and I need to make more of a "ledge" for the bights to sit on. Again, I dont know lol CW Quote
Members Hollywood Posted July 30, 2010 Members Report Posted July 30, 2010 Howdy Everyone, So I have always struggled with burying my string ends successfully to where you dont see the cut off end, and it doesnt bunch up as you push it back through. I have tried using an exacto knife and pull the string as tight as I can get it then cut the excess off as close as I can get, so that when its loosened back up it will be hidden, but about all I was able to do was put cut marks in parts I didnt want to. Any advice or tricks on how to attractively bury ends would be greatly appreciated. Thanks, CW I manufactured a small piece of Brass Shim micro in thickness ( Not quite sure what you caled it in the States .) tapered to fit under the strand you are cutting ( like a small cutting board ) Push the shim under the strand , pull the strand tight and use a scapel to cut across and at a backward taper . The strand ( Kangaroo especially ) will recind back under the top strand never to be seen again . Using this method you will never cut through the undelaying string and get a perfect bury John Quote
Members Leatherpownder Posted July 30, 2010 Members Report Posted July 30, 2010 Howdy Everyone, So I have always struggled with burying my string ends successfully to where you dont see the cut off end, and it doesnt bunch up as you push it back through. I have tried using an exacto knife and pull the string as tight as I can get it then cut the excess off as close as I can get, so that when its loosened back up it will be hidden, but about all I was able to do was put cut marks in parts I didnt want to. Any advice or tricks on how to attractively bury ends would be greatly appreciated. Thanks, CW I use cutical nippers. the edge is straight and will cut close. Quote
Members Spence Posted July 30, 2010 Members Report Posted July 30, 2010 I use my fid as a shim (as described by Hollywood). I also skive the ends to thin them down for the last tuck or two. I then push a bit of glue under the last tuck, pull on the string, insert the fid and cut it off. Whatever works works. Quote
Members KnotHead Posted July 30, 2010 Members Report Posted July 30, 2010 I usually tuck the finish strand and start strands all the way under and nip them both at their perspective ends of the bight structures ie. ( Top and Bottom, or Left and Right Sides) depending on how you're looking at it. I will use a pair nail clippers, or a box razor, nippers I use with electronics, or whatever will give me a nice fine close cut. Knot Head. Quote
Members entiendo Posted July 30, 2010 Members Report Posted July 30, 2010 Perhaps you can post a picture. I love hollywood's idea for cutting the last string. Quote
Members 8thsinner Posted August 14, 2010 Members Report Posted August 14, 2010 I have a three colour pineapple to do within the week and will probably have trouble hiding all six ends. I have never been overly happy with my method either but after a while they do go into hiding and can't be seen so it's usually fine, but I usually have one or a max two colours... I like the shim idea, normally I use an extremely sharp knife (most any knife closer to me usually works.) Pull as tight as possible and slice through until it snaps off, then bury the rest with a pin/fid or even knife tip depending which one was handy... I might try the knot heads method though with this knot... Quote
Members KnotHead Posted August 15, 2010 Members Report Posted August 15, 2010 I have several photos. But none where you can see the tucked ends. LOL... Now there's an irony. LOL... Brian... Quote
