What Color To Use? it might help if you use english,
charlie
hello what color should I use brown black leather ... I use white ... which one to use ?(translated)
I would use black leather, and do the lettering in white
sorry I did not know very English with translation error
the question was what color I use on black leather that is resistant thanks
Edited by billio8
I think you want to know what Paint to use:-)
The only options with white is acrylic (or oil based paint) Both of these do not penetrate the leather, just putting themselvs on the surface, that means that in due time they both will wear of.
I have made some experiments with artist oil paint, diluted it with oil and terpentine, it works fine on veg.tan leather, it does penetrate more than other kinds of paint (but way less than dye) and hold up better than most other paints I have used. The downside is that it has to dry properly before adding the sealer, it can take weeks (and more).
I hope this help you a bit along the way :-) //Tina
You can also mix the acylic white with water.
That is how I do white but you have to paint many layers to make it cover.
The advantage here is that the acrylic paint will penetrate the leather and not just sit on top. Looks alot better that way with almost intact leather structure.
I can't know for sure but it should be more resistable against wear and weather and I always use a sealer on acylic paint.
Tom
