  • Replies 20
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Larry, I think your holster looks great as well. You wouldn't be able to post a pattern for te floral design on yours would you?
I have been making the Threepersons-style holsters for many years. About 18 months ago I commissioned a very talented man to recreate the carving pattern on Tom Threepersons' original holster. Since that time orders have been steady.
I have always thought that floral and Sheridan-style carving were best displayed with a natural oiled tan finish. Some customers like an antique finish. Some like the black-inked background.
I recently receive an order for the carved Threepersons-style holster in cordovan brown. I was somewhat concerned that the dark finish would not properly display the carving work, but when it was finished I found it to be a real eye-catcher!
Here it is. 8-oz. Hermann Oak lined with 3-oz. calfskin, dyed, lightly oiled, sealed with acrylic and final finish of Bag Kote. It carries a Smith & Wesson Model 29 .44 magnum 4".
As always Lobo, your work is great, and an inspiration for many. Mike
NOTE TO SELF: Never try to hold a cat and an operating Dust buster at the same time!!
At my age I find that I can live without sex..........but not without my glasses.
Being old has an advantage.......nobody expects me to do anything in a hurry.
I'm not only newto leatherwork, but I'm also new to forums. I realized today what I haddone.
Lobo, I apologize. This post is about your work and I should not have posted anything exceptwhat I said about the beautiful work you did. I hope you and the othermembers did not take any offense. It was a rookie mistake and I feel bad. I feel especiallybad since Lobo helped me several times with problems that only his experience could solve.
Maybe themoderator can delete my post, if so I would appreciate it.
If some one cantell me how to get the floral design on the forum, I'll start another post and try toget it out there.
Again, Lobo, I apologize. Larry
Lobo, Again, I can't say enough about how much I like that holster. Of all of your work I've seen, that has to be my personal favorite. I have a question for you. I've never lined a holster, and I was wondering how much extra work that entailed and how much extra you charged for the lining.
Edited by gregintenn
Larry: Please don't feel bad. No harm, no foul. I enjoy seeing what other people are doing as well.
Lobo Gun Leather
serious equipment for serious business, since 1972
www.lobogunleather.com
Lining a holster is not difficult. I lay out my lining material and stretch it on a flat surface. Then I apply cement to the holster's flesh side (Fiebing's Tanners Bond works well), lay the holster out on the lining material, and press them firmly together as the cement cures (a weighted board works well). I cut the lining materal about 1/2" away from the holster edges. All edges that will not be sewn during holster assembly need to be sewn now. After stitching in the edges you can cut the lining closely to the edges. Then it is assembly and stitching as usual.
On a typical holster I estimate that installing a lining adds about 15 minutes. Material cost will vary from perhaps $1 to $3, depending on what you are using.
I charge an additional $18.00 for lining most holster models.
Lobo Gun Leather
That's a beautiful holster Ray. I can see why the orders have been coming in for that one.
A couple of questions if you don't mind -
What is your method of dyeing - dip, dauber or spray? When I've used cordovan it sure seems to come out much darker than that. I've been dip dyeing.
You said you use Bag Kote as a finish after the acrylic. IIRC Bag Kote can be very hard to come by, correct?
Is Tan Kote nearly the same?
One more, does the Bag Kote mellow the high gloss that Acrylic leaves or is there another purpose it serves for you?
Big River Leather
DLCP228MahogcharcoalEleph001small_zpsniz
I dye using an immersion method, submerging the holster in the dye solution. This provides very good penetration so that surface scratches and abrasion seldom penetrate beneath the dyed surface.
While I refer to the results in the color shown as "cordovan brown", I do not use cordovan-color dye. Because I use neatsfoot oil as part of the finishing process, applied after dying, I have found that lighter browns are significantly darkened by the neatsfoot oil. I settled on a dye mixture that produces the color shown after oiling. I know that many others argue against neatsfoot oil, but I continue to use it to replace some of the natural moisture that is lost in the tanning process, and further diminished by wet-forming, etc. In my opinion, veg-tanned leather that has been cased and formed ends up very dry and can be somewhat brittle, sometimes resulting in cracking at stress points subjected to flexing during use. I am probably re-igniting the old arguments about neatsfoot oil, but I know what has worked for me over the past 38 years and I will continue doing that.
Bag Kote is produced by Fiebing's and many suppliers carry it. Bag Kote costs about $12 or so per quart, and a quart will finish a couple of hundred items easily. It is similar to Tan Kote in the finish produced. I've used Bag Kote for years and I like the mellow sheen that it provides.
The acrylic sealant that I use is a mixture that I have been producing by combining a couple of other products that, when used together, will effectively penetrate and seal both the outer surface and the flesh sides very well. As some things seem to happen, this mixture was discovered by accident, but the results have been very satisfying so I keep making the same accident happen! This can be used to produce a high gloss finish, but that is not what I wish to accomplish. Bag Kote provides the final finish that I prefer, and it also contains waxes that help to resist minor scratches and abrasion better than the acrylics, in my experience. Regular maintenance needs can be taken care of using nothing more than neutral shoe polish, which is easy for the customer to obtain and use.
Best regards.
Lobo Gun Leather
Hey Lobo!
What a great looking result you got with your fininshing. I really appreaciate your willingness to share your finishing techniques with the rest of us. I don't know about anyone else around here, but whether it's my wood projects or my leather projects, I love the process of designing and constructing but I'd rather have a root-canal than put finish on them!!
I have re-read your description of the finishing steps you use, and I have two questions. First, when you say "antique" I assume you mean liquid antique and not paste? And you apply it after the initial light coat of neatsfoot oil. Do you let the oil absorb and dry or do you antique directly after the oil coat starts to even out?
Thanks again for being willing to school those of us who are interested. I've been making holsters since 1981, and I can't say I've really been happy with the finish on any of them!
Mike
My choice early in life was either to be a piano-player in a whorehouse or a politician. And to tell the truth, there's hardly any difference.
Harry S. Truman
