The soldering iron sounds like a great idea. Did a quick search and there seem to be some reasonably priced options, plus they seem to get 2-3 hours on one butane cartridge so I imagine you can finish a LOT of stitches on one fill.
So doing this you never have issues with a sharp point sticking out?
EricDobson.com - My Neglected Blog
  • Replies 20
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Also, is this type of soldering iron basically instant-on, or does it need to be kept warmed up somehow?
You can melt and with the tool, just kinda press the thread down... it leaves no sharp type piece of thread.... you can rub it with your finger if there is anything sticking up (when still warm/hot).
It takes about 20-30 seconds to be hot enough to melt good.
I use it every time and it works so perfect. I was worried at first, but once i found this trick... YES... very happy!!
Someone else posted something about this a while back. They said to backstitch a few stitches, and then clip the threads and put just a tiny drop of super glue on the cut ends. I've also heard, and use, clear fingernail polish. I used to tie knots and then melt, but as was mentioned, it either left a black smoke mark, or it left a sharp point. I haven't used the fingernail polish method for long, but so far it seems to work.
Every method you mention here (not your, but others ideas I think) are a big pain in the butt... messy (glue) etc etc.
The tiny butane soldering iron works SO easy, clean, neat etc. Yes, still backstich two-three holes, snip and solder. PERFECT way to do it.... it can't come undone aft er this, unless somebody really tried hard to get it apart.
Alright you convinced me. I'm just getting started with basic stitching in the next couple weeks. I'll give all these methods a try and see how it goes. I can definitely imagine the benefits to soldering. I like the idea that you're not adding a substance, or gluing it together, or coating it, but just melting the thread itself so there's nothing to come apart or undone. I'm not saying the other methods do come apart if done well... I just like the idea of this better. I'll have to see how it actually works out.
Then there is the electric cautery. Mine is a Bovie and they seem to be the largest player in the game and everyone calls them that no matter what the brand. Mine came from the Vet, new in the box for about $20. I've had it for years so it's not something new. It uses AA batteries and heats up in about 2 or three seconds. Works like a soldering iron but finer tip, tips are replaceable but I haven't needed a new one yet. It is about the size of a big pen.
Tips get verrrryyyyy hot!
Art
I did a search and found some cautery pens, in the price range & battery size mentioned, but they all seem to be advertised as single use. Do you know if there are some that aren't? Or is that just what they say and you can use them indefinitely with this light use?
The Bovie I have has replaceable tips so I don't think it is for single use. Maybe the newer ones are but if it had replaceable tips it is for multiple use. The ones I have seen in hospitals are fixed units with a cord that stay in the OR. Nowadays, instruments are sterile in bags, and I wouldn't expect very good results after running mine through the autoclave. In that way, single use yes, but they use them multiple times during a surgery to fix bleeders etc.
Art
  • 3 weeks later...
Hammering the seam so the stitches closing around the thread. Then cut the thread all off with a sharp pointed scissors dont burn it.
Trox
I just received my Cobra Class 4 a couple of weeks ago. Love the machine but still trying to figure it out. I've been hand stitching for over a year and went to a machine to save time. When I clip the thread after sewing it will unravel at times leaving a hole from the thread. I guess I'm clipping the knot that holds it together? What do others do to prevent this? Back stitch a couple of times, burn the thread, tie a knot, etc. Any advice would be greatly appreciated.
Tor
Workshop machines: TSC 441 clone/Efka DC1550, Dürkopp-Adler 267-373/Efka DC1600, Pfaff 345-H3/Cobra 600W, Singer 29K-72, Sandt 8 Ton clicking machine, Alpha SM skiving unit, Fortuna 620 band knife splitting machine. Old Irons: Adler 5-27, Adler 30-15, Singer 236W-100
