Members roo4u Posted September 25, 2010 Members Report Posted September 25, 2010 i dont think thats the same thing the small boton is tied similar to a gaucho knot not started as a turkshead. Quote
Members skyout Posted September 25, 2010 Members Report Posted September 25, 2010 (edited) Thanks Tracy, Here are the Grid Maker links to the 2 pass + the 3 pass Gaucho Fan Knots. This is the 9x8 2 pass Gaucho knot, which is enlarged from a 5x4 2 pass Gaucho knot (Hall calls this 5x4 Gaucho a very small Spanish Ring knot). I made this grid after Brian showed us the 3 pass below. 2 pass Gaucho Fan Knot Brian, aka: knothead, showed us this grid over on KHWW.net. Brian's thread on the Grid Maker 3 pass Gaucho Fan Knot Sorry, hope I'm not hijacking the thread too much. Rick skyout Edited September 25, 2010 by skyout Quote
Members roo4u Posted September 25, 2010 Members Report Posted September 25, 2010 no the small boton is similar too the gaucho knot but not the same... the edges are o2u2 but the center is o3u3. in the large boton the edges are o2u2 and the center is o6u6 Quote
Members skyout Posted September 25, 2010 Members Report Posted September 25, 2010 no the small boton is similar too the gaucho knot but not the same... the edges are o2u2 but the center is o3u3. in the large boton the edges are o2u2 and the center is o6u6 Thanks Tracy. See if these look better (the bights can be adjusted following the common divisor rule to make a larger knot). Small boton knot Large boton knot Quote
Members roo4u Posted September 25, 2010 Members Report Posted September 25, 2010 nope not those either....here are the over unders from bg book the small boton oriental or small fan knot. begin as a gaucho knot of two passes. thong is passed up around mandrel and then back down o1, up o1, down o2, up o2, down u1 o2, up u1 o2, down u2 o2, up u2 02. now here is where the difference starts. down u3 o2, up u3 o2, down o1u3o2, upo1u3o2, down o2u3o2 up o2u3o2, down o3u3o2, up o3u3o2, down u1o3u3o2, up u1o3u3o2, down u2o3u3o2. now the working end is brought around u2 alongside the standing. and your done. 3 section fan or boton oriental begin up thong is wrapped twice around mandrel now down o1 u1 o1, up o1u1o1, down o2u2o2, up o2u2o2, down u1o2u4o2, up u1o2u4o2, down u2o2u6o2, up u2o2u6o2, downo1u2o3u4o1u2o2, up o1u2o3u4o1u2o2, down o2u2o4u4o2u2o2, up o2u2o4u4o2u2o2, down u1o2u2o5u5o2u2o2, up u1o2u2o5u5o2u2o2, down u2o2u2o6u6o2u2o2, working end bought around 2 along side standing end your done!!! i will try to post pix of these and the large and small pampas knots during construction sometime in the next couple of days. hopefully it will help you to follow the instructions. Quote
Members skyout Posted September 25, 2010 Members Report Posted September 25, 2010 (edited) nope not those either....here are the over unders from bg book the small boton oriental or small fan knot. begin as a gaucho knot of two passes. thong is passed up around mandrel and then back down o1, up o1, down o2, up o2, down u1 o2, up u1 o2, down u2 o2, up u2 02. now here is where the difference starts. down u3 o2, up u3 o2, down o1u3o2, upo1u3o2, down o2u3o2 up o2u3o2, down o3u3o2, up o3u3o2, down u1o3u3o2, up u1o3u3o2, down u2o3u3o2. now the working end is brought around u2 alongside the standing. and your done. Thanks Tracy, The run list helps a lot. Here's the small one. http://tiny.cc/6blb2 And the large boton. http://tiny.cc/yolf9 Thanks for sharing and I hope this is it. lol Looking forward to seeing your pics! Rick skyout Edited September 25, 2010 by skyout Quote
Members skyout Posted September 27, 2010 Members Report Posted September 27, 2010 (edited) OK, after looking closer at the half cycle run lists, the 3 section fan or boton oriental in Grant's book only has 8 bights while the link in the previous post has 11 bights for a larger knot. So here's the grid for the 25part x 8bight 3 section fan or boton oriental. http://tiny.cc/je6im I've also included the two grids into the Grid Catalog at KHWW. Thanks again so much Tracy and I can't wait to see your bracelets. Rick skyout Edited September 27, 2010 by skyout Quote
