Members Big O Posted September 20, 2010 Members Report Posted September 20, 2010 I got a small stitching awl, with a size 1 blade. Cuts right through even a double layer of 8-9 oz leather. I love that. BUT.....I've got this thick 4 oz Nyltec waxed nylon thread, and I have to use pliers to get the needles and thread through the holes made by the awl. I mean, I have to push the needle in from one side, and then pull it out from the other. When I'm finished sewing, it looks like there's a puckered area around each hole. Is this because the awl is too small, or because the thread is too thick, or because I'm pulling the thread too tight, or some combination of those, or something I haven't thought of? Quote https://www.facebook.com/BigOGunleather
Contributing Member TwinOaks Posted September 20, 2010 Contributing Member Report Posted September 20, 2010 It could be a combination of all three. A single needle should pass through an empty hole easily, all the way to the thread in the eye, then need just a little tug. The second needle will be just a little harder. When back stitching, I sometimes need to assist the last pass with pliers, but that's the 4th pass through the same hole. The puckers sound like you're pulling WAY too hard, or stitching while the leather is too wet. Quote Mike DeLoach Esse Quam Videri (Be rather than Seem) "Don't learn the tricks of the trade.....Learn the trade." "Teach what you know......Learn what you don't." LEATHER ARTISAN'S DIGITAL GUILD on Facebook.
Members Kevin Posted September 20, 2010 Members Report Posted September 20, 2010 Bigger awl. Kevin Or smaller needles and thread and stitch length Quote
Members katsass Posted September 20, 2010 Members Report Posted September 20, 2010 On 9/20/2010 at 10:51 AM, Kevin said: Bigger awl. Kevin Or smaller needles and thread and stitch length Just a thought, are you stitching after applying your finish? The fact that you use pliers to pull the needle through doesn't matter much to me....I do it with all of my stitching...at least I know that the thread will not loosen and back out. I stitch after dieing but before applying my finish. Mike Quote NOTE TO SELF: Never try to hold a cat and an operating Dust buster at the same time!! At my age I find that I can live without sex..........but not without my glasses. Being old has an advantage.......nobody expects me to do anything in a hurry.
Members Big O Posted September 20, 2010 Author Members Report Posted September 20, 2010 On 9/20/2010 at 1:40 PM, katsass said: Just a thought, are you stitching after applying your finish? The fact that you use pliers to pull the needle through doesn't matter much to me....I do it with all of my stitching...at least I know that the thread will not loosen and back out. I stitch after dieing but before applying my finish. Mike After. I'm actually "cheating" - using leather that's already finished. I have some undyed leather on the way, though. Quote https://www.facebook.com/BigOGunleather
Members katsass Posted September 24, 2010 Members Report Posted September 24, 2010 On 9/20/2010 at 7:58 PM, Big O said: After. I'm actually "cheating" - using leather that's already finished. I have some undyed leather on the way, though. I suspect that part of the problem is the finished surface of the leather. Try working with a piece of unfinished scrap and see if you stitching doesn't look better. Mike Quote NOTE TO SELF: Never try to hold a cat and an operating Dust buster at the same time!! At my age I find that I can live without sex..........but not without my glasses. Being old has an advantage.......nobody expects me to do anything in a hurry.
MADMAX22 Posted September 27, 2010 Report Posted September 27, 2010 The prefinished leather shouldnt cause a issue. I finish most of my leather before stitching. I think the biggest thing to consider is awl size compared to thread and needle size. I am with twinoaks on this one, I only need pliers when I am back stitching. I found that having to use pliers all the time became very time consuming and ended up just not being much fun. It seemed to double the time it would take to stitch say a belt or something which would put you from 2 hours to 4 or so. Another thing with hand stitching is remember to do it the same way for every hole. This will lend to more uniform stitching. It took me a while to get this down but I realized even if I started out with a bad habit or doing it slightly wrong to just keep doing that till it was done and it would still turn out looking pretty good. Quote
Members BAD HIDE Posted October 15, 2010 Members Report Posted October 15, 2010 (edited) If you're having trouble pulling through every hole, there's something amiss. Either your awl blade is too small or your needles are too big. I generally sew with small needles and two awls, one bigger than the other (not by much, but noticeable, it's really just a brand new blade that hasn't been sharpened down much). All my starts and stops, wherever I'm going to pass 4 threads through it, I'll use the bigger awl and even twist it to make the hole bigger, and then it's still tight but no problem getting the needles to go through with just my fingers. Then switch to the smaller awl and go to town. I probably have to use pliers maybe once every 2-3 hours of sewing, but definitely not every hole. Once you figure out what's causing the extra resistance and can sew without the pliers, your speed, consistency, and your stitches will be a lot better. As far as the puckers, lighten up on pulling your threads - they really don't need to be any tighter than an easy squeeze - and make sure the leather is dry. Edited October 15, 2010 by BAD HIDE Quote Badhide.com
