Members jfhspike Posted October 4, 2010 Members Report Posted October 4, 2010 I'm a complete amateur -- please forgive me if I use the wrong words. I sew a fair amount of boat stuff, but nothing leather. But you folks seem to really know your stuff, so I want to pick your collective brains. I just picked up a Singer 31-15 for $50 yesterday. (To be honest, the table and motor are worth that to me, so it's a no-lose deal!) The previous owner warned that he'd used it a lot a few years back, but tried it recently and couldn't get it to "hook" properly. Well, I've got a Pfaff 130, so I'm not scared of the innards, and I took apart the bobbin-holder parts, and cleaned out a few pounds of lint and other greasy stuff, shoved it back together, and managed to get it actually sewing (under hand power, since I was doing this on the workbench rather than in the sewing-table that it came with). Tension adjustment was a bit of a mess, though: the upper thread pulled through the material (some fairly tight webbing), and the bobbin-thread ended up pretty much straight. That was with the upper tension cranked down all the way. So...I lowered the bobbin tension (the screw was ALL the way in, and took some oomph to unscrew!) and managed to make it even things out a little, but the stitching seemed very loose; the lower tension had to be AWFULLY light to make it work. (Still tight enough that when I held the bobbin-case-assembly by the thread, it didn't drop, but it was close to dropping.) Of course, all this was with the needle that was on the machine already. Kinda rusty looking, kinda "popped" as it pushed through the webbing. Now I'm ready to actually check the timing, etc., using the manuals that others have pointed folks to on other 31-15 threads here on leatherworker.net (thanks, everyone!) But I have a few questions for you as I try to get this thing going right: I'm planning to sew stuff on the canvas cover for my boat. It's reasonably heavy duck -- not quite sunbrella-heavy, but close. Mostly it'll be simple seams -- the needle going through 2-4 layers of the stuff, although at hems, esp hem-corners, we might be talking about 8 or 9 layers. 1. In the interest of longevity (this cover's on the boat for 6 months at a time, outdoors, exposed to sunlight, albeit winter sun).. I'm hoping to use V-92 polyester thread;Sailrite says #18 or #20 needle. Can this machine use those sizes? 2. I know I'm supposed to use 16x87 series needles, but they seem to come in several kinds of points. (Am I right that one of these is "ball point"? Sounds like a Bic sewing needle!). Can you give me a hint of what point-kind I need? 3. When I lift the presser-foot, the tension discs don't seem to relieve the tension much. Any thoughts about how to adjust this/fix this? 4. Anyone got any suggestions about the tension? When I loosened the lower tension, I adjusted the upper tension and got things to work...well...OK. But I was still getting dropped stitches and stuff. Unless I hear from someone with suggestions about it, I'll wait until I've got new needles, etc., before pursuing this further. 5. The oiling holes seem to have some gurry in them --- do I need to clean out every bit of this? Or am I seeing something like felt that's meant to hold a bit of oil, and cleaning it out will only mean that I'm screwing things up? Misc. Does anyone know why things like thread and needles are called "notions"? Thanks in advance! --John Quote
Members jfhspike Posted October 4, 2010 Author Members Report Posted October 4, 2010 Two more things... 1. The manual says "left twist thread should be used in this machine" Am I right in thinking that essentially all thread that I'm likely to buy is in fact left-twist thread? 2. I'll be using cones of thread. The Sailrite folks say that I should pull the thread from the top of the cone to add twist, so it looks like I need a thread stand. But can someone tell me how you route thread from the stand to the machine? If I just run it from the guide at the top of the stand to that first little "button" that it goes around, about 4" above the tension discs, I worry that it won't be leading to that thing from the right direction. Am I just being a worry-wart? ---John Quote
qarawol Posted October 4, 2010 Report Posted October 4, 2010 I too just purchased the Singer 31-15 fairly recently. I am just getting started myself on using it. I maybe able answer a few of your questions though. 1) yes the machine will handle a #18 or #20 needle for 69 thread 2) no idea what point needed for that material. My machine will be used for leather 3) There is a small pin that is in the center of the tensioner assembly that is pressed by a lever on the inside of the head assembly. That pin may be missing or stuck. 4) there should always be some tension on the lower thread. To the point where it will not just drop if you only held the thread. Actual adjustment should be made with the thread size that is to be used. 5) mine too has felt on some of the top holes. They are only at certain holes though. Some oil points needs the oil to drip on an internal part. I myself have not tested the thread twist on any of my threads that I have used to play with. I have not yet purchased actual nylon or polyester thread yet and have only been using cotton thread to practice with. I have ordered 138 and 69 thread so that i can start making things. Practice time is over. No idea on thread on cone usage yet. I hope this helped a little. Someone with more knowledge may chime in. Njoy Life... Quote 'qarawol' = "Quality And Reliability, A Way Of Life..."
Members jfhspike Posted October 4, 2010 Author Members Report Posted October 4, 2010 On 10/4/2010 at 4:39 AM, qarawol said: [...] 1) yes the machine will handle a #18 or #20 needle for 69 thread [...] 3) There is a small pin that is in the center of the tensioner assembly that is pressed by a lever on the inside of the head assembly. That pin may be missing or stuck. 4) there should always be some tension on the lower thread. To the point where it will not just drop if you only held the thread. Actual adjustment should be made with the thread size that is to be used. 5) mine too has felt on some of the top holes. They are only at certain holes though. Some oil points needs the oil to drip on an internal part. Thanks very much -- all useful information. I'll go ahead and do some minimal cleaning and then oil the thing and see whether I can get it to run nicely. (It runs pretty smoothly already). I'll try the drop test to adjust the bobbin tension. -John Quote
Members jfhspike Posted October 4, 2010 Author Members Report Posted October 4, 2010 On 10/4/2010 at 2:39 AM, jfhspike said: Two more things... [...] /quote] And ANOTHER thing... The leather belt on this machine was broken, so the seller whipped up something from a piece of old extension cord, held together with electrical tape. Amazingly enough, this was tough enough to do the job and show that the machine ran OK, at least for the short term. But I clearly need to replace it. I've seen replacement leather-belt stock, with belt-hooks, but I ask myself "is there something more modern than this?" At Grainger, I see stuff like this: http://www.grainger.com/Grainger/round-belts/power-transmission-belts/power-transmission/ecatalog/N-cc0Z1z0o4ds Is that what folks use nowadays? Or am I missing something obvious? (The belt that needs replacing appears to be 42" with a 5/16" diameter.) --John Quote
qarawol Posted October 4, 2010 Report Posted October 4, 2010 (edited) That belt should work fine if you want to spend and buy that much as well as buy the needed splicing kit. I don't know if the staple clamp will work on that material. Since you really don't need much, look at eBay for the belt. Search for " 5/16 leather belt ". 1/4" or 5/16" diameter will work though mine is and I prefer 5/16". You'll find a single belt or many footage for future use. As with most new belts, use it a bit and readjust as needed since they will stretch a bit. Njoy Life... Edited October 4, 2010 by qarawol Quote 'qarawol' = "Quality And Reliability, A Way Of Life..."
Members Kevin Posted October 4, 2010 Members Report Posted October 4, 2010 As you have seen with the power cord, the belt isn't that complicated. I usually just use heavy skirting and make either a round belt or a vee belt, depending on what is needed, or you can go to any parts store and get a belt, take it home and cut it to the length you need, butt the ends together and join the ends with heavy thread. The belt isn't running at a high speed and the thread will hold up as well as a staple. Kevin Quote
Members jeeperaz Posted October 4, 2010 Members Report Posted October 4, 2010 (edited) Quote And ANOTHER thing... The leather belt on this machine was broken, so the seller whipped up something from a piece of old extension cord, held together with electrical tape. Amazingly enough, this was tough enough to do the job and show that the machine ran OK, at least for the short term. But I clearly need to replace it. I've seen replacement leather-belt stock, with belt-hooks, but I ask myself "is there something more modern than this?" At Grainger, I see stuff like this: http://www.grainger....g/N-cc0Z1z0o4ds Is that what folks use nowadays? Or am I missing something obvious? (The belt that needs replacing appears to be 42" with a 5/16" diameter.) --John Thats what use... or similar at least. I use o-thane from http://www.campbell-bosworth.com/ They sell it by the foot (a buck per?).... they also have the connectors. I love the stuff... seems to make the machine run more precise. Edited October 4, 2010 by jeeperaz Quote
Members jfhspike Posted October 5, 2010 Author Members Report Posted October 5, 2010 On 10/4/2010 at 10:06 PM, jeeperaz said: Thats what use... or similar at least. I use o-thane from http://www.campbell-bosworth.com/ They sell it by the foot (a buck per?).... they also have the connectors. I love the stuff... seems to make the machine run more precise. Thanks, Jeeperaz (and Kevin!). I'll probably just stitch together the electrical cord for now, while I wait on other bits and pieces, now that I know the loads are modest, etc. By the way, something very similar to that O-thane is available from McMaster-Carr, where I should have looked first. But they don't sell the connectors individually. --John Quote
Members jfhspike Posted October 5, 2010 Author Members Report Posted October 5, 2010 On 10/4/2010 at 4:39 AM, qarawol said: 3) There is a small pin that is in the center of the tensioner assembly that is pressed by a lever on the inside of the head assembly. That pin may be missing or stuck. I went and looked at things, and couldn't see how that pin would work...until I looked at the parts book and found that the disks were assembled in the wrong order. The correct order is machine, disk1, disk2, spring-holding-disk, spring, knurled nut On my machine, the order was machine, disk1, disk2, spring, spring-holding-disk, knurled nut It gave the same net pressure on the disks, but it meant that the spring-holding disk never got pressed by that little pin. Thanks for prompting me to go look carefully. You never know what you'll get with a used machine... --John Quote
