Members glennaycock Posted October 20, 2010 Members Report Posted October 20, 2010 I was under the impression that the Seiko STH-8BLD-3 was identical to the Consew 206RB-5, possibly even made in the same factory. I went with the Consew for upholstery and general leather sewing. I also ordered a SewPro 500GR and 2" pulley, which I'm hoping will give me excellent control and torque at low speeds. I received and installed the 500GR, but I haven't gotten the 2" pulley yet. It does have a lot more torque on the low end than the other servo motor, and I'm able to do 1-2 stitches/sec by barely pressing the pedal. However, it's still very fast with just a bit more pedal. Still, a good investment I think. Hopefully the 2" pulley will make even more improvement. I tried adjusting the brake, but could not break the spring-bolt by hand and didn't want to strip it. Quote
Moderator Wizcrafts Posted October 20, 2010 Moderator Report Posted October 20, 2010 I received and installed the 500GR, but I haven't gotten the 2" pulley yet. Hopefully the 2" pulley will make even more improvement. My SewPro 500GR servo motor, purchased from Toledo Industrial Sewing Machines, came equipped with a 50 mm, a.k.a. 2" pulley. What size is on yours? Where did you buy it? You can reduce the pot setting on the back of the motor for slower top speed. Just stay above 50% and you'll be fine. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members glennaycock Posted October 20, 2010 Members Report Posted October 20, 2010 My SewPro 500GR servo motor, purchased from Toledo Industrial Sewing Machines, came equipped with a 50 mm, a.k.a. 2" pulley. What size is on yours? Where did you buy it? You can reduce the pot setting on the back of the motor for slower top speed. Just stay above 50% and you'll be fine. It came with a 75mm/3" pulley. I got it on ebay directly from SewPro (I think). The pot is turned all the way down. I'm still waiting for my 2" pulley. Hopefully it will arrive tomorrow. Thanks, Glenn Quote
Moderator Wizcrafts Posted October 20, 2010 Moderator Report Posted October 20, 2010 It came with a 75mm/3" pulley. I got it on ebay directly from SewPro (I think). The pot is turned all the way down. I'm still waiting for my 2" pulley. Hopefully it will arrive tomorrow. Thanks, Glenn I hope you ordered the small pulley from SewPro, or an authorized dealer. That motor has a smaller diameter shaft than clutch motors and big servo motors. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
