I bought a new Novolene Chopping Block from Weavers, on the recommendation of someone here (I think) and wow.... after using my 3/8" punch 3 or 4 times, it is totally trashed!
What the heck do you all use as a back-stop or whatever, when punching holes? I'm bummed, but at least I learned it with the lower cost punch instead of one of the $60 bag punches I bought!!
Should I use the semi-soft poundo board? At least with that, I dont think it will hurt the punch. What good are those Novolene boards if not for punching holes?
The punch just rolled into itself....
:head_hurts_kr:
The tool was junk when you bought it. Using it 3 or 4 times will not trash the tool. How much does the maul weigh you are using?
  • Replies 29
  • Created
  • Last Reply
Top Posters In This Topic
Sounds to me like the punch was not heat treated correctly, or poor material. I would expect a punch to chip an edge before rolling over.
I use end grain wood, be it soft, or hardwood, but always end grain.
You laugh at me because I am different. I laugh at you because you are all the same.
Did you perhaps sharpen the punch when you first received it? I received a pair of punches from a local shop that's very well known - I won't mention their name because a lot of people seem happy with their work, but I certainly wasn't one of them. From day one, I couldn't punch through a single layer of leather with a 3lb mallet without striking it about 10 times. I sharpened it considerably because the edge was way too blunt of an angle. After that, it cut WAAAAAY better - once or twice, until it rolled the edge over because the angle was too shallow... I've since reduced the angle, and even had a member here sharpen them for me a while back. They cut okay, but I'm not at ALL happy with them - especially when they split the leather at the curved end of a belt slot on a double-layer of 8/9 oz. I can't afford new ones at the moment, and I didn't feel like sending them back because the lady on the phone was rude and tried to blame their dull punches on me, saying I must have dropped them (way out of line, and I NEVER dropped them) and then said I ruined their punch when I tried to sharpen it. What a joke.
I guess you could buy fishing sinkers and melt them down. Or you might get a bag of shot for a shotgun and melt that down. Or if you have a recycle place close by they might have some. Old wheel weights would work fine to. If i was going to make one i'd get the cheapest old cast iron skillet i could find melt in that and use it to shape your lead. But the cheapest and easiest is to do is get a plastic / nylon cutting board. They work fine and last forever and they won't dull your punches or knives. But i seem to be about the only here that uses them. The wood end grain block dosen't last very long if you do much punching in my world. But use what works for you.
I'm old enough to know that i don't know everything.
hey dirtclod thanks for the reply the SHOT from shotguns isnt lead uphere, they stopped that i think awhile ago,lead and lake water not a good idea in any amount, i will try the cutting board makes sense clicker presses are made with heavy plastic, although the melting of fishing sinkers skillets wheel weights sounds even better we recycle everything up here and that stuff is easy to come by!
I would think that you get lead shot. Do skeet shooters have use steel shot ? As far as duck and goose hunting it's the same here steel only. You can get the cutting boards at wal mart for around $10.00 USD. I get the white ones their about a 1/2 inch thick and come in all different sizes.
Im not sure for the skeet shooters but the way things are going here (GREEEEEN) i dont think lead is around anymore could be wrong, the cutting board is the best idea will be getting one tomoro the local wal mart is walking distance from everywhre they take up 10 000 sqare blocks lol thanks for the help
I use a polypropylene cutting board `20" x 40" x 1" thick. It works great. I can't imagine a leather shop without one. These tools we use ain't cheap ya' need all the help ya' can get to keep them functioning properly.
I punch on a poundo board, but used scrap for years - a good sized piece of sole bend. I also had my father make my bench with an unfinished pine top, so if I do slip and drive something into it there's no damage to anything but the bench. Ten years on, it looks like hell, but I'm not after cosmetics in my basement shop.
