Happy Hooligan
Which Singer Is This?
I think I'm going to replace my old singer with this one or at least add to it.
He's asking $85 for the whole set up. It sounds pretty good to me.
Which model is this one? anything I should look for?
3k13oe3p15W55U25R6acfc5f80f93cf011292.jpg?t=1292528139
This is a 111w that has a walking foot will sew just under 3/8" use 46,69,92,138 thread.Parts are still available as are feet.
At $85.00 it's a bargain,esp if it sews.
BHTH,
Bob
looks like a singer 111w 155 walking foot uses a 135x16 needle, there should be a brass tag w/ the number on the front of the machine.
Just picked it up tonight.
It will need a new timing belt. Even came with a bunch of bobbins and other stuff.
It was at one time repainted gray... was black. I think they took the model plate off so I don't know which one it is.
Now to oil it up and order some parts....
On the top shaft your going to have to pull off the belt pulley then the bearing,does this bearing have screws in a collar that have to be loosened to get it off?If so it's a 111w155.
We also pretty much have every part in stock for this machine.
I'm going to open the oil up the machine this weekend. I know the timing belt needs replaced for sure.
thanks for the heads up on all parts needed... I'm sure I'm going to be needing a few parts to get it sewing again.
Cleaned it up a little today and oiled it up. It now turns very smooth.
some better shots of it...
is this the screws you were talking about?
this is the motor that came with it... is this a good one or will it run too fast?
I'm a nuB here~ sorry for resurrecting this old post. This is a 111w115? It looks just like my 111w103...? Also, it seems to be the consensus here that the 111's spin too fast. I'm going to use mine exclusively for leather/vinyl/fabric upholstery~ no gun scabbards or saddle repair for this retired cowboy! Will speed still be an issue? How important is it to have reverse?
Edited by albyneau
