That's y'all for the replies. I've ordered 12 spools of Tejas Waxed Thread in 3 different colours from Tandy a few months back and after using some, have delegated them to use as paper weight. These stuff has so much wax on them that it leaves a huge mess of wax at the stitching holes after you've pulled them through. I've tried de-waxing it some by pulling it through a piece of pinched leather. Not much help.
I've since moved on to a waxed polyester which is ok I guess, since i mostly make wallets.
  • 3 weeks later...
  • 2 weeks later...
I was taught to finish the ends this way.
Back stitch twice.
Then go half way through the third stitch and out between the two pieces on both sides.
Both ends should come up between the pieces of leather.
Tie the ends together with a simple knot and pull tight, do this twice.
Snip the ends close to the knot, leaving maybe .25 inch.
Tuck everything down.
Everything is hidden between the pieces of leather. No need to singe the ends.
