Members fivesixthree Posted March 4, 2011 Author Members Report Posted March 4, 2011 I got the demo at Sheridan and then had some time to sit and play with it. The quality and design are up to usual Luberto "built like a tank" standard. Finish is good, no shortcuts were evident. I have only one problem with it. The motive power is a crank on the side of the machine (where a traditional balance wheel would be). I just have a problem with cranking that thing and feeding the work. That's not saying I wouldn't get used to it after a while, it cranks away from you unlike most balance wheels, which is a good thing. I have no problems working my No.9 with the wheel on the front, but the crank on the side might take some time to appreciate? It is a little more fluid than the Boss, and I would have a hard time deciding between the Cub and a Cast Iron (original) Boss. With the prices the way they are today, You should seriously consider a powered short arm 441 clone, unless portability is a factor. Art SUPER THANKS FOR THE ADVISE IM USING IT NOW WITH EXCELLENT RESULTS VERY GOOD BAD ASSS MACHINE Quote
Moderator Art Posted March 4, 2011 Moderator Report Posted March 4, 2011 Please turn the caps lock off. So, did Tony move back to Connecticut from Montana? Art SUPER THANKS FOR THE ADVISE IM USING IT NOW WITH EXCELLENT RESULTS VERY GOOD BAD ASSS MACHINE Quote For heaven's sakes pilgrim, make yourself a strop!
Members daleoffshore Posted November 22, 2011 Members Report Posted November 22, 2011 Please turn the caps lock off. So, did Tony move back to Connecticut from Montana? Art It's been a while for this thread,but I've been in contact with Tony on a problem with the no9 my Dad had.He was patient and worked me thru it,and He plans on getting things moving again. He's back and forth between Ct and Mt. Quote
