Members johnggrg Posted January 26, 2011 Members Report Posted January 26, 2011 Ok this will be the first time ever applying a finish coat to leather. I have both Eco-Flo satin and super sheen finishes. I had a question. I am going to use the satin on my first holster. I have read to apply with a damp sponge or with a brush. Then let dry and buff. Can it be applied with a rag?(t-shirt) I tried this on a scrap piece that was dyed already and it seemed to soak in. Would this be another way to do it if the sponge or brush were not available? Like I said I did try this but wanted to know from the pro's. Please let me know what you think. John Quote
Members particle Posted January 26, 2011 Members Report Posted January 26, 2011 I used Satin Sheen on my holsters and was very pleased with how easy it was to apply. I took a damp sponge paint brush, dipped it in the Satin Sheen, then brushed it on liberally, going back over the holster as I went along to make sure the entire holster stayed damp - this helps it to soak in, and also keeps it from drying too much. Then, with a folded paper towel (that I folded up before I started applying the satin sheen), use the same spot on the paper towel and wipe down the excess. The Satin Sheen will transfer to the paper towel, dampening it - as you rub over the holster to remove the excess, you will also be smoothing out the finish and removing some of the streaking. Let it dry completely in front of a fan, then repeat the process again. I usually followed up with a light airbrushed coat of Resolene, but it probably wasn't necessary. I don't think it overly matters what you use to apply the stuff - just so long as it's a little damp to begin with. The last thing I'd say - don't over work it. Apply, remove the excess as noted above, then hang it up to dry - don't get consumed with trying to wipe away all the streaks, or you'll just gum up the whole thing. I used Satin Sheen on the holster in my 'how's it made' video on my website, and I show how I applied it in case you'd like to see it. Quote Eric Adamswww.adamsleatherworks.com | Facebook | YouTube | Instagram
