steve mason
Pfaff 145-545-1245
Howdy;
I have a question for you machine experts if you don't mind.
I am wondering the differance between the pfaff 145, 545, 1245.
As far as I understand the 1245 is a newer model of the 545 with some minor changes to the bobbin winder, not sure about the 145, is it the same as the 545 but with a smaller bobbin? Are all three machines high lift with the 190 needle system?
thanks much
steve
Edited by steve mason
Hi Steve,
Not sure on your question. Clarifying, if the machine is a H3, it uses a 134-35, but if it is a H4 (high lift) it uses the 190. 190 is a little longer than the 134-35. Timing however is the same.
Art
Howdy;
thanks much
steve
the 145 is very similar to the 545, but is older, and uses a smaller bobbin. most of the parts are interchangable. the 1245 is the newer version of the 545. on any of these machines you can set the needle bar height for either the 134-35 needles, or the 190.
Hi Steve,
Art
Help!i purchased a Pfaff 145 H3 head only and the knee lift mechanism is different than most i have seen so i am looking for that mechanism and also a source for parts for these machines any Help i will be most Grateful...
Sincerely,
Patrick Hubbert
pat.hubbert@att.net
Try this company:
http://www.universalsewing.com/tek9.asp?pg=parts_pfaff
Actual page: http://www.universalsewing.com/images2/parts_lists/all/aokko5oe.pdf
You do know that machine is an upholstery machine?
ferg
Sincerely,
Patrick Hubbert
pat.hubbert@att.net
