Members rgerbitz Posted March 29, 2011 Members Report Posted March 29, 2011 When repairing saddles and you need to remove the rivets in the riggings or on the stirrups what do you use to get the little buggers out? Thank you, Rob Quote http://gerbitzquarterhorses.com/
dirtclod Posted March 29, 2011 Report Posted March 29, 2011 I take a pointed drive punch and make a dimple on the peened part of the rivet. Then use a drill bit one size bigger than what's needed. Drill and get the washer off then take your drive punch and knock the rivet out. A piece of metal with a hole bigger then the rivet in it really helps if you put it under the rivet so it theirs something to hold the rigging and let the rivet fall into. I've been saveing the rivets i take out for almost 20 years and i'm gonna take em and sell them one of these days. Quote I'm old enough to know that i don't know everything.
Members TroyWest Posted March 29, 2011 Members Report Posted March 29, 2011 Take a spike, or a sharp flat head screwdriver and strike the washer to the left of the burr, then to the right of the burr. you may have to do this a couple of times but the copper washer will fold up, grab it with some nippers and pull it off. You can then nip the burred end of the rivet off with the nippers and now drive the rivet back out with a spike or punch over the piece of metal with the hole drilled in it. This is very fast and effective. Quote
Members Randy Cornelius Posted March 29, 2011 Members Report Posted March 29, 2011 I use a dremel with a small cut off wheel that I cut the burr off then the washer come off and you can drive the rivit out. When removing Blevin buckles use the cut off wheel to remove the burr and washer, pull off the first layer of leather then use the cut off wheel to cut the rivit off flush with the blevin buckle and then drive the rest out with a punch and hammer. A steel plate with a hole drilled in it underneath helps a bunch. I will not use a drill and bit as I has one break on me one time and drove the broken bit through my hand, OUCH! Randy Quote Randy Cornelius Cornelius Saddlery LaCygne, Kansas Randy & Riley Cornelius Ride Hard, Shoot Fast and Always Tell the Truth...
Members rgerbitz Posted March 29, 2011 Author Members Report Posted March 29, 2011 Great, thank you all. Rob Quote http://gerbitzquarterhorses.com/
Members Saddlebag Posted April 22, 2011 Members Report Posted April 22, 2011 I use a drill press. The trick is to put a blob of saliva on the rivet, then drill thro it. This is an old welder's trick who said the spit works better than water. Besides, it handy and there's always a ready supply. Quote
mike59 Posted April 22, 2011 Report Posted April 22, 2011 I use the dremel tool,...works every time! On 3/29/2011 at 12:23 AM, rgerbitz said: When repairing saddles and you need to remove the rivets in the riggings or on the stirrups what do you use to get the little buggers out? Thank you, Rob Quote
Members oldtimer Posted April 22, 2011 Members Report Posted April 22, 2011 (edited) Most important is that you don´t generate too much heat so the leather around the rivet will be destroyed ! Edited April 22, 2011 by oldtimer Quote "The gun fight at the O.K. corral was actually started by two saddlemakers sitting around a bottle of whiskey talking about saddle fitting"...
Hennessy Posted July 25, 2011 Report Posted July 25, 2011 On 3/29/2011 at 2:21 AM, TroyWest said: Take a spike, or a sharp flat head screwdriver and strike the washer to the left of the burr, then to the right of the burr. you may have to do this a couple of times but the copper washer will fold up, grab it with some nippers and pull it off. You can then nip the burred end of the rivet off with the nippers and now drive the rivet back out with a spike or punch over the piece of metal with the hole drilled in it. This is very fast and effective. a piece of 2x4 with a hole big enough to allow the rivet place to go will work too Quote
