alb Report post Posted April 15, 2011 THe document I have showing the oiling of the consew 225 refers to filling the oil well that surrounds the hook with oil and soaking the pad alongside the bobbin case. My consew doesn't have a felt pad and I can't tell from the picture where the oil well is. Does someone have a picture shows the oil well and the felt pad? Thanks! Ann Quote Share this post Link to post Share on other sites
albane Report post Posted April 16, 2011 THe document I have showing the oiling of the consew 225 refers to filling the oil well that surrounds the hook with oil and soaking the pad alongside the bobbin case. My consew doesn't have a felt pad and I can't tell from the picture where the oil well is. Does someone have a picture shows the oil well and the felt pad? Thanks! Ann http://consew.com/default.aspx?pageId=4 Quote Share this post Link to post Share on other sites
CowboyBob Report post Posted April 16, 2011 Years ago when this machine was made they had bobbincases that has a felt on them,they haven't made them with it on for years so just put the oil in the groove were the bobbincase sets give it a drop maybe once every 1/2hr of sewing,& put some oil on the 2 pivot points under the hook & you'll be OK. Bob Quote Share this post Link to post Share on other sites
CowboyBob Report post Posted April 16, 2011 Here's a pic of the pad that was supposed to hold the oil.I've marked the 3-spots that you should oil.If you fill this well up you have a big mess,so if you oil these 3-spots often the excess will run down in the well anyways. Bob Quote Share this post Link to post Share on other sites
alb Report post Posted April 16, 2011 Thank you so much gentlemen!!! Ann Quote Share this post Link to post Share on other sites
