Members v8sharkie Posted April 25, 2011 Members Report Posted April 25, 2011 Hi All! I'm new here, but found some helpful info on this forum before. Now I've got a real question. I've got a footpress and I'm looking for a die that will work with the Weaver 104 double cap rivets OR if anyone knows where else I can get heavy duty rivets like those and a die to match that'd be great! I'd like to find them in silver and brass if possible. The footpress is a standard like those used for jean rivets, snaps, grommets, etc. Thanks for any help in advance! Quote
Ambassador Luke Hatley Posted April 25, 2011 Ambassador Report Posted April 25, 2011 (edited) Hi All! I'm new here, but found some helpful info on this forum before. Now I've got a real question. I've got a footpress and I'm looking for a die that will work with the Weaver 104 double cap rivets OR if anyone knows where else I can get heavy duty rivets like those and a die to match that'd be great! I'd like to find them in silver and brass if possible. The footpress is a standard like those used for jean rivets, snaps, grommets, etc. Thanks for any help in advance! Ohio Travel Bag will have what you need. Ps, the 104 are not double caped, you will have to order the caps for the 104 tube rivet seperate. Edited April 25, 2011 by Luke Hatley Quote
Members v8sharkie Posted May 24, 2011 Author Members Report Posted May 24, 2011 Ohio Travel Bag will have what you need. Ps, the 104 are not double caped, you will have to order the caps for the 104 tube rivet seperate. Luke - thanks so much for the response. I took your advice and looked at Ohio Travel Bag. I ordered the rivets, caps and dies for these. I was told the dies should fit my kickpress if its American made (which Im pretty sure it is since its a standard kickpress). Anyways, I just got the dies and rivets and unfortunately the dies do not fit. Any ideas where I can get dies that will fit my machine? I need dies for Ohio Travel Bag's #252 Rivets and #40 caps that fit these rivets. The kickpress I have is like this one: http://www.hikerusa.com/KICKPRESSES.html Thanks! Quote
