Your favorite method
155 members have voted
  1. 1. What is your favorite way to cut down big pieces of leather?
    • Head knife
      58
    • Scissors
      18
    • Craftsman knife/utility knife
      39
    • Depends on the leather
      25
    • Other (please explain)
      15
I cut 90% with head knives...my favorites being Gomphs and W. Rose. I like the smaller blades and I take a lot of time removing the shoulder of the knife back about 3/4". Confidence comes with practice, of course, but with a sharp headknife it is reasonable to expect to cut straight never wander outside the pencil line. I also use a couple of small sharp straight knives...they look like parring knives....and for tight radius inside corners, I use a swivel knife first and then finish with a small straight knife. I think the saddlemakers will bear me out here...ounce you learn to correctly sharpen and use a head knive, you'll also find yourself skiving with one, which saves a lot of time and effort! Just my humble opinion..... :cowboy:
  • 2 weeks later...
  • Replies 34
  • Created
  • Last Reply
Top Posters In This Topic
I use a reed knife I acquired from my wife when she got a new one.
Just keep it sharp.
eschew obfuscation
  • 2 weeks later...
For straight and moderate curves, you can't beat the rotary cutter. This little tool will cut thru 8-9 OZ like hot butter.....
I concurrrr completely a rotary cutter and a drywall t square cuts like nobodies business!
Have you ever come across a pro quality rotary knife?
So far I've had great luck with just a utility knife and a broad blade x-acto. I have a friend who is a knife/sword smith and I'm negotiating with him now to make me a custom head knife
My round/head knives are my first choice for most leather. Cutting, skiving. A carpet knife works great for rough cutting parts. For trimming I use a small trim knife, one straight blade and one curved, purchased from Weaver. For those tight corners, I design the curve to fit one of my hole punches or strap end punches. It leaves a bit of clean-up work where the two cuts meet, but it's better than trying to get a round knife around it on thick skirting.
As for sharpening, I use a Galco sharpening system with the guide for the correct angle. It's the only thing I've been able to get a good edge with. I can shave with it. A strop board keeps all my knives nice and smooth between sharpening.
Straight lines are not a problem with a head/round knife. It does take a while on thick, firm stuff but you have the control and you can see where your cut is going. I find that pulling a knife is more difficult to control and I can't see where the line is going because it's behind or under my hand and arm.
Edited by Go2Tex
Brent Tubre
email: BCL@ziplinkmail.com
