Members Danne Posted July 1, 2021 Members Report Posted July 1, 2021 (edited) I mainly use Fenice and Uniters. But I have two different primers for Uniters (I don't use them though) EP FILLER and EP FULL. EP FULL one coat and one coat EP2000 give a rounded edge that seems to be durable. I haven't tried how durable though. I go the long route (sanding edges rounded, paint a layer and heat it, paint 4-5 more coats with sanding in between and finish with melting wax and burnish.) Time consuming but durable. See example with EP-FULL (Polyurethane) at the bottom One coat of EP Full, One coat of EP2000, light sanding with 800 grit and polished with some paraffin wax. Edited July 1, 2021 by Danne Quote
Members sbrownn Posted July 2, 2021 Members Report Posted July 2, 2021 On 7/1/2021 at 2:18 PM, Danne said: I mainly use Fenice and Uniters. But I have two different primers for Uniters (I don't use them though) EP FILLER and EP FULL. EP FULL one coat and one coat EP2000 give a rounded edge that seems to be durable. I haven't tried how durable though. I go the long route (sanding edges rounded, paint a layer and heat it, paint 4-5 more coats with sanding in between and finish with melting wax and burnish.) Time consuming but durable. See example with EP-FULL (Polyurethane) at the bottom One coat of EP Full, One coat of EP2000, light sanding with 800 grit and polished with some paraffin wax. Beautiful edge. Quote
