Members brettra Posted May 12, 2011 Members Report Posted May 12, 2011 Hello everyone, I've made a belt for my daughter. It was dyed and then I applied glitter with a spray adhesive. I tried adding a few layers of adhesive over the glitter but she still managed to wear off some of the glitter simply from wearing. Can anyone advise what will make a good top coat that will keep the problem from reoccurring? I'm worried about flexibility and cracking. Quote
Members Dwight Posted May 12, 2011 Members Report Posted May 12, 2011 Bretta, . . . my favorite, hands down, product for final finishing of belts is Resolene. Dilute it to a 50/50 solution of Resolene and water, . . . brush it on with a cheap bristle brush, . . . (brush until you get a coat of bubbles, . . . then brush till the bubbles all disappear), . . . you may have to do a couple of coats. We buy it here in the states in a small 4 oz bottle, . . . it is worth the investment to try it on a scrap piece, . . . but if I were a gambler, . . . I'd bet you will like the results. It is a good, tough finish. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Members brettra Posted May 12, 2011 Author Members Report Posted May 12, 2011 Bretta, . . . my favorite, hands down, product for final finishing of belts is Resolene. Dilute it to a 50/50 solution of Resolene and water, . . . brush it on with a cheap bristle brush, . . . (brush until you get a coat of bubbles, . . . then brush till the bubbles all disappear), . . . you may have to do a couple of coats. We buy it here in the states in a small 4 oz bottle, . . . it is worth the investment to try it on a scrap piece, . . . but if I were a gambler, . . . I'd bet you will like the results. It is a good, tough finish. May God bless, Dwight Thank you Dwight and thank you for the ditution instruction. I will order in a bottle and give it a go. I appreciate the voice of experience. Regards, Scott Quote
