The snaps i currently have are not deep enough to go through two 7/8 pieces of leather plus the loop and then still crimp to the back side of the snap.
What should i use? i checked tandy didnt see anything deeper. unless i missed something.
any help is appreciated. Tried searching but couldnt come up with anything. Thanks
I use panhead machine screws of #6-32 size in lengths of 1/4", 5/16", and 3/8" depending on the thickness of the pieces I am securing. A T-nut is set into the leather from behind, then the male stud of the snap is secured to the T-nut with the machine screw passing through the center hole (where the rivet base would normally go).
T-nuts with 1/4" shaft length work well. 1/4" is very close to the thickness of two layers of 7-8 oz. leather.
Machine screws can be selected for the length necessary, keeping in mind that one thickness of 7-8 oz. leather is approximately 1/8". I keep screws on hand in the lengths listed above, which seem to meet all of my needs.
Buying in small quantities at a hardware store will help you figure out what sizes and lengths you need for your designs. Then you can purchase by the hundreds or thousands and get much better prices. Bolt Depot (www.boltdepot.com) has been a good source with a broad selection and reasonable prices. You'll find T-nuts under the "nuts" tab, and machine screws under that tab.
I use the #6 T-Nuts as well, but I place them between the front and back pieces of leather so the holster has no exposed hardware.
For IWB I only use stainless t-nuts and either brass or stainless screws. Unlike the others I use #8 screws and reform the heads. I also trim down the spikes and place the nut between the layers of leather. I think it gives a more finished appearance. Jmho.
