Members Jimbob Posted May 21, 2011 Members Report Posted May 21, 2011 hey there ya all.... Is there a foam that suits the bike seat best....what kinf of foams you biker seat guys are using....?? I see neoprene....? What density would you recomend....is there a special foam for seats only.....anybody has a great suplier?? Does it make sense to mix foam....I read, last layer is finishing foam.....how does this work?.........what foam is best when inserting a gelpad.....!!?? Ohhhh, and what kind of foam is the foam most manufacturer use on their plastic pans?? Greetings thanks James Quote http://www.elfwood.com/~alien883 First it is just leather....then it is what-ever I can dream off...
Members rickeyfro Posted May 21, 2011 Members Report Posted May 21, 2011 I do all my solo seats with high density closed cell neoprene, usually 3/4" thickness, I get it here, http://www.foambymail.com/neoprene.html quick service and free shipping over $75. I get the hi quality its much denser, i use the regular quality to back up inlays of exotic skins, usually in 1/8 or 1/4 thickness. The foam that Ive found on most of the pre made vinyl covered seats looks to be nothing more than sofa cushion foam rubber. Far from ideal, holds water like a sponge whereas closed cell neoprene will not hold water. hey there ya all.... Is there a foam that suits the bike seat best....what kinf of foams you biker seat guys are using....?? I see neoprene....? What density would you recomend....is there a special foam for seats only.....anybody has a great suplier?? Does it make sense to mix foam....I read, last layer is finishing foam.....how does this work?.........what foam is best when inserting a gelpad.....!!?? Ohhhh, and what kind of foam is the foam most manufacturer use on their plastic pans?? Greetings thanks James Quote
