Mactechbri
Another Holster To Look At. But Im Still New At This.
I DO like it. Simple, effective, and attractive :-)
The only thing I might would do different is to make the belt loop a little tighter to the belt to reduce some slack when drawing. Of course, if you have wider belts that you wear it on, then it would probably be just fine with those.
Nice work. What button snaps did you use on this holster, and how do you like them?
Oh- and thanks for the construction pics! It's always helpful and interesting to see the build phase of a project.
Nooj
Edited by Nooj
I used Line 24 Snaps from Tandy. They are pretty good. Not too hard to snap/unsnap, and not too easy either.
I know what you mean about the belt loop. I realized it was a tad too big after I riveted it on.
Im still figuring things out though.
Bri
I used the same snaps on a ax sheath recently. I must've bent 5 of the caps, trying to set them. Can you get to the strap on your holster to un snap it fairly well?
I have to do a lot of figuring out on all of my projects, so you aren't alone, lol. The holster I'm about to finish I glued up, tore apart, and re-glued three times before I finally had it how I wanted.
Nooj
Im finding that both rivets and snaps seem to want to tilt to one side. I never seem to get them perfect.
I am assuming that they are supposed to mushroom inside. But seem to slide one way or another. They are holding though.
I saw your ax sheath last night, it looks good.
Brian
When you set the snaps or rivets go slow taps and roll the tool around the head as you go, seems to work way better than Beating the (*&^ out of it! LOL I tried the hammer away first, rolling the tool works perfect and leaves a clean tooling. I wish I had a pistol to practice with. Im liking this leather working!
Steve
"slow taps and roll the tool around the head as you go"
This is the kind of stuff I come here for. It only would have taken another 50 or so snaps to figure that out.
I will try that next time.
Bri
