Mike Craw Posted November 25, 2008 Report Posted November 25, 2008 Hey Jon! Do you happen to have a link to John's site? Google keeps trying to tell me I spelled it wrong. Thanks. Mike Quote My choice early in life was either to be a piano-player in a whorehouse or a politician. And to tell the truth, there's hardly any difference. Harry S. Truman
Members steve mason Posted November 25, 2008 Author Members Report Posted November 25, 2008 Hey Jon!Do you happen to have a link to John's site? Google keeps trying to tell me I spelled it wrong. Thanks. Mike http://www.ljsaddlery.com Quote check out www.stevemasonsaddles.com check out my saddle blog
Members kseidel Posted November 25, 2008 Members Report Posted November 25, 2008 G'day David' Many years go (seems like another life) I made mostly show saddles and the natural unoiled look was the most popular; and still enjoys that honor. I found that the saddles without any oil discolored quickly due to UV rays and staining, no mater how bulletproof the finish. I began experimenting with different oils that would not darken significantly and would help to give life back into the leather aiding in the resistance to discoloration. This is when I discovered that it is not so much the type of oil, but the application that affects the color most. Oils with the lightest viscocity will yeild the lightest color. But even they will be dark if applied too heavily. I Use Olive oil on most of my new saddles now. The depth of color is determined by how much oil is applied, and how quickly. A light coat of oil followed immediatly by another light coat will be much darker than the same two light coats with 8 - 12 hours between. The real "art" in a light color is how the oil is applied. Hand applying with a sheepskin allows the most control. The amount of oil on, or "in" the sheepskin pad is the key. If you will wipe most of the oil out of the sheepskin and begin with ultra light pressure, you can achieve a very minimal coverage. Increase pressure as the oil dispenses from the pad maintaining the same amount of oil being applied to the surface. The pad will quickly become "empty" and you can rub over the surface again lightly to smooth out any streaks, befor getting more oil. An oil's wicking property is also important. Many oils are blended or sulfinated using water or other substances as a carrier. The better the oil wicks, the deeper it will penetrate and not pool on the surface. There is no substitute for time to allow oil to penetrate. A good rule of thumb is to wait 8-12 hours before applying another coat. With olive oil, the final color is not evident for 3-4 days. Different oils impart different colors. Even sulfinated oils or oils with great wicking properties will give a different color. How the oil reacts with the tannins in the leather will deternine the final result. Sunshine will also affect the color; either before or after oiling will have different affects. I use an oil here called TeeSee that is the most natural color that I have found other than leaving natural. Olive oil darkens as much as neatsfoot oil, but has generally better wicking properties and less oil will thoroughly condition, leaving less close to the surface. One coat will penetrate completely, where most neatsfoot oils never panetrate completely. The only neatsfoot oil that I have found that penetrates as well as olive oil is from Texas Refinery. I do not know of a finish that is perfect for all natural saddles. None that I know of will stop the discoloration of UV rays from the sun. Unless you ride the saddle only inside, It will change color. When finally oiled, the saddle will then darken significantly. Most finishes will have to be stripped before oiling will be affective and even then will usually be blotchy. Acetone strips most lacquer finishes well, but not some like tan kote or bag kote. These are water based finishes that, once set, are very difficult to remove. They also do not protect well against staining and discoloration. They are a good topcoat for sealing. I prefer fiebings Colorless Harness Dressing for a topcoat on saddles that are going to be re-oiled frequently. It is NOT completely colorless and is not a suitable finish for natural saddles. However, it can be re-applied many times without build up, and readilly accepts oil without any stripping. It is more difficult to apply without streaking. Neat lac is still my favorite for most durable finishes. I like to work it into the leather like oil, and apply at least two light coats. The lighter colored saddles that you have seen that I have made are antiqued. My process for this finish is as follows: after all tooling and shaping is complete, wash the leather with oxalic acid solution to remove any surface stains from handling and to prep the leather. Oxalic acid opens the pores and makes the leather very receptive. Then oil to the depth of color that I want... maybe one coat, maybe several. Wait at least 6 hours after last coat of oil before applying any tip coat. There must not be any oil left on the surface or the lacquer will not stick. Then apply a thorough coat of Neat Lac, rubbing it well into the surface. When dry, apply a coat of antique, working it into the tooling, and then buff off any excess. Follow with another coat of Neat Lac, controling the final drying for finish. If you want a high gloss finish, simply apply and leave alone to dry. If you continue to wipe your pad over the surface lightly as the lacquer dries, it will finish satin or even flat. It takes a little practice, but you can get a very natural finish. The antique process certainly does darken, dependign somewhat on the color of the antique. I use mostly mahogany, but on the show saddles, I used light mahogany for a lighter color. You can also remove a lot of the antique with the final lacquer coat. Most of these saddles need to be re-finished after about a year and and a half to two years. They will darken quite a bit when first re-finished. With this much Neat Lac and antique, it takes a long time for the oil to penetrate. Once it does, another coat will penetrate fairly quickly. I usually give them a really good cleaning which helps to remove some of the old finish. Completely re-finishing as original will make the saddle look close to new only a bit darker shade. Sorry for the length of this post. Your question required a long answer. I hope this is the information that you wanted. Keith Quote Keith Seidel Seidel's Saddlery www.seidelsaddlery.com
Mike Craw Posted November 25, 2008 Report Posted November 25, 2008 Thanks Steve! I can see why John enjoys the reputation he has. Mike Quote My choice early in life was either to be a piano-player in a whorehouse or a politician. And to tell the truth, there's hardly any difference. Harry S. Truman
hidepounder Posted November 25, 2008 Report Posted November 25, 2008 I've been biting my tongue reading responses to this topic for days. I'm always interested in what products others use for finishes and how they are applied. The process Keith described for finishing is pricisely the way I was taught and continue to practice. I have been paticularly interested in the adverse comments about Neat-Lac....thinking I was just out of date and out of touch, because I love the stuff! As a point of interest...while working at Porters, years ago, Neat-Lac was the only sealer allowed to be used on saddles or any other gear or equipment. We reconditioned a lot of saddles in those days and all of them went out soaped/oiled and Neat-Lac'd. Smells pretty good too! Quote
Members Shelly Posted November 26, 2008 Members Report Posted November 26, 2008 Keith, Do you like to use the antique paste, or the liquid form of antique?? Quote Shelly
Members kseidel Posted November 26, 2008 Members Report Posted November 26, 2008 I prefer the paste antique. Partly because I have more experience with the paste. I don't like highlighters. Just can't get the same effect. Some of the paste antique is pretty thin and has a lot of liquid floating on the surface. This is harder to use and has a tendancy to penetrate the base coat of neat lac, making the leather quite a bit darker. Do you use liquid antiques? If so, what kinds and what are the properties and effects? Maybe There is something new that will work better..... Keith Quote Keith Seidel Seidel's Saddlery www.seidelsaddlery.com
Members Shelly Posted November 26, 2008 Members Report Posted November 26, 2008 HI, Actually, I don't use the liquids - paste here, as well. I was really hoping you might have given them a try and had a comment or two about them...maybe someone else on the forum has used them, and can tell us what they do/don't like about them, and what applications they like to use them in. I've been having issues with some of the edge dyes...on my headstalls, personal goods, casework, etc, and saddles on occasion, if I dye edges, I can wait overnight before applying finish, and the dye wants to strip off on the wool pad, and muddy the tooling - pisses me off! I've tried really light applications, etc, and get the same results...one thing I tried recently that was interesting - did a belt for a customer, and, rather than using the same old steps as before, I had seen Feibings had a edge dye that has the sponge applicator, sort of like shoe polish - gave me the idea to try using a big Marks A Lot, with the real wide end - the permanent type. I used that on the belt, did my finish, and had hardly any bleedoff to speak of on the wool pad. I considered that almost a home run - pretty easy to apply, not messy, and after I let it dry a few hours, was easy to finish and it didn't muddy up the rest of the work...I was hesitant to mention this method on the forums, just because it didn't seem to carry over as 'very professional'...but, sometimes if it works...I wish I could find these markers in mahogany or cordovan...some type of brown... Quote Shelly
Moderator bruce johnson Posted November 26, 2008 Moderator Report Posted November 26, 2008 Shelly, I was taught to use Sharpies for edges 15 years ago. The saddlemaker that showed me that, also was using them for background dyeing and lettering besides edges. I have used several brands over time, and have some favorites. I like the Pilot refillable carton markers in black for edges. Add extra ink to keep them moister than you might want for paper. I buy them and the refill ink bottles at a local office supplier. They have the "jumbo" nib and do a good job on most edges with one pass. I have some chisel point makers in brown also. I think they are MarksALot. Sharpie makes a nice fine and ultra-fine marker in brown also. I have tried some other brands and these are my favorites. One brand of black marker looked alright, but faded to a lovely purple color in about two weeks. I tossed those. I have found the normal Sharpies do a better job for me on leather (oiled or not yet) than the "industrial" Sharpies. The Industrials sometimes are a little streaky. I don't do much work with other colors. I have not had the demand or expectations for much color work. I had a guy a couple years ago who wanted a Bible cover with a cross in silver and old turquoise. The robin egg blue Sharpie marker on oiled leather gave me the turquoise color, and the silver Sharpie gave me the silver. I'll attach a pic for the example. Saved me messing around ordering color dye or acrylics, and gave a good durable coloring. I use the reds some, but not much else. With some of the reformulations and products being discontinued, I think we are going to have a lot of new things to play with. Part of it is going to be borrowing chemicals and finishes from other venues like the wood finishers and office suppliers. Plain carton and sign markers can be bought from a few suppliers. Beilers sell them. You can put spirit dye in them, edge dressings, what ever and slather it on edges too. Quote Bruce Johnson Malachi 4:2 "the windshield's bigger than the mirror, somewhere west of Laramie" - Dave Stamey Vintage Refurbished And Selected New Leather Tools For Sale - www.brucejohnsonleather.com
Members Go2Tex Posted November 27, 2008 Members Report Posted November 27, 2008 I prefer the paste antique. Partly because I have more experience with the paste. I don't like highlighters. Just can't get the same effect. Some of the paste antique is pretty thin and has a lot of liquid floating on the surface. This is harder to use and has a tendancy to penetrate the base coat of neat lac, making the leather quite a bit darker.Do you use liquid antiques? If so, what kinds and what are the properties and effects? Maybe There is something new that will work better..... Keith I bought a quart bottle of liguid antigue from Zack White about 6 years ago. Still have some left, so I don't use it too often, since I also prefer the paste. But the Zack's stuff will get down into the fine cuts and when I need a little touch-up close to stitching where I need a lot of control, I apply it with a small brush. Zack's resist is an acrylic, very much like Resolene and seals the leather completely. Of couse, you can't get oil through it. Quote Brent Tubre email: BCL@ziplinkmail.com
