Members poseidon Posted June 3, 2011 Members Report Posted June 3, 2011 got this from a local shoe leather supply and I just want to ask if you guys can tell if this is real leather? it doesn't smell like leather but I know this method does not always work? or it does? Quote
mike59 Posted June 3, 2011 Report Posted June 3, 2011 In my opinion, it is real leather. The close-up photo shows not only the clamp marks from the tannery, but the grain fibers on the edge. I think it safe to say you weren't skunked. Quote
Members poseidon Posted June 4, 2011 Author Members Report Posted June 4, 2011 I thought so but the smell is not like the other kind of leather i've handled Iguess you really can't base it by the way they smell thanks sir. Quote
Contributing Member TwinOaks Posted June 4, 2011 Contributing Member Report Posted June 4, 2011 Since you got it from a shoe leather supplier, most likely that is not veg-tan. It's probably chrome tan, or perhaps even oil tan leather. It would be good for pretty much anything that will see a lot of flexing, like a wallet back, or the like. It probably won't mold very well, either, so keep that in mind when you plan your project. ( i.e. not the best leather if you want to make a sheath or holster) Quote
Members $$hobby Posted June 5, 2011 Members Report Posted June 5, 2011 got this from a local shoe leather supply and I just want to ask if you guys can tell if this is real leather? it doesn't smell like leather but I know this method does not always work? or it does? when in doubt, burn it. if its real leather or some other form of animal skin, it will smell like it when burnt. shave off a sliver and burn it. if you dont know what it should smell like, try taking some known leather and burn it. btw, be aware of sole leather. its treated with some chemicals. Quote
Members poseidon Posted June 5, 2011 Author Members Report Posted June 5, 2011 thanks for the tips guys it's real leather it is im turning it into a belt:) Quote
Members Nod4Eight Posted June 9, 2011 Members Report Posted June 9, 2011 It looks like oil tanned leather to me. I use it a lot to make chinks - very durable. It won't take a stamp or mold at all, but should work fine for a belt, although it is difficult to burnish the edges. I'm not sure how you plan to cut it. A draw knife won't work very well, the leather is not stiff enough. I lay it flat, keep it tight and use a long strait edge and a sharp blade. Don't over stretch it unless you want a curvy belt, sometimes I clamp the strait edge to hold it tight and avoid the leather slipping underneath. Get the cleanest cut you can. Good luck and have fun! Quote
