Finished last pipe out of Hackberry. Repolished stem and bowel
after picture-Going to brother in law.
Joe
post-13948-074828300 1308493868_thumb.jp
  • 3 weeks later...
That is one right fine pipe and your brother-in-law will be proud to have it. I know I surely would. How did you shape it? Are you going to line the chamber with anything or burn it?
Not going to line it. Just smoke it. Let the tobacco build up a cake inside.
Joe
This pipe is what i call a Colonial
post-13948-095554800 1309959147_thumb.jp
Forgot about how I shaped it.
used a dermal with flex shaft -spiral wood cutting dill bit- wide tooth cutter. Drill press for bowel hole.
Hand drilled air passage on stem. Bench wood saw, 1inch x 30inch belt sander and a 4inch band sander.
did between 3pm and 5pm on bench while enjoying the afternoon. I can not measure worth a filp, so
I just eye ball it.
Joe
post-13948-095586600 1310042675_thumb.jp
I might have to give that a try. I would need to get some different wood than what I have right now. All I have is pine. You have piqued my interest. Thanks Stewart.
