Good afternoon all.
I just got a new press from HF. It is a 12 ton machine. I ordered 2 pieces of gum rubber in a 40 hardness. (they had a 40 hardness in three different scales, I got medium soft. I hope it is the right stuff, $76 each.). I got it setup last night and took some wet leather and a blue gun and pressed it together, just to see what it would do. It was just two scraps, not sewn together. I put it down snug, but there was not really any significant tension in the jack handle. About the same you could do with just your hand on the bottle neck pump with out the handle. The inside of the leather took a really good inpression of the gun, down to the lettering, etc. The outside on the other hand barely showed any detail at all. My question is, how much pressure should I be using. Even though they are just molds, the blue guns are still $50 each. I would hate to smash one.
Any insight into these machines would be much appreciated.
Thanks.
Good afternoon all.
Thanks.
Funny that you posted this because I just got the latest flyer with the 20 ton press on sale for $149.99 the cheapest I have saw it http://www.harborfre...ress-32879.html (need to get the coupon in the flyer at the store to get the sale price). A press has been on my list for some time so I hope you get some good feedback on your posting because next I need to find where to buy the rubber and at what hardness
I will get a ruling from BLUEGUNS and post it about the pressure I do know that some models have steel rods in them which may help.
Edited by RMB Custom Leather
Thank you,
Rob Bennett
Email: rob@rmbcl.com
Authorized Distributor
BLUEGUNS
Multi Molds
Maker Supplies
Home of the "Taco Press" kydex/Leather former
FREE SHIPPING!
FACEBOOK
Thanks Rob, i would very much like to know what Blue Guns says also. I got the guns from you last week and just picked up the press (on Sale) Friday. Anxious to get started.
Hatcreek, . . . whatever pressure you used to get
is adequate pressure for what you want to do.
If you are looking to get the outside to pick up all the details of the weapon, . . . you literally will be disappointed. All a press is used for is to make the contact against the weapon in the "inside" that makes for good retention.
The outside details are produced by boning the object after the press work has been done.
I use 40 durometer gum rubber, purchased from McMaster-Carr on my press, . . . but I am about to change that, . . . as the work I am doing now does not need the press.
If anyone is interested, . . . I would probably sell my rubber plates, . . . as I really don't use my press much at all anymore.
I have used my 8 ton press for several years now, . . . using blue guns, . . . have never hurt one with it.
May God bless,
Dwight
www.dwightsgunleather.com
Hatcreek, . . . whatever pressure you used to get is adequate pressure for what you want to do.
May God bless,
Dwight
Dwight,
I understand what you mean about the detail, I have been using a vaccumm press for a while now and I do the boning after it is out. What I am looking at is when i vaccumm mold, the leather will for suck up around the gun more around the slide, frame and trigger. I want the same from the press, I am just very concerned about over doing it.
I saw one post that they really put alot of tension on the press, for both blue and real guns. I am just worried about over doing it. 12 tons sounds like a lot of pressure. i will make another holster tonight and post some progress photos tomorrow.
Jim
You will not get the same pull down around the periferyof the weapon that you get with the vaccum when you use the press and rubber pads. Dwight is correct about the press. You don't need or want anywhere close to the pressure it can produce. What you can get is the lines of the weapon exposed on the exterior so you can chase them with your boning tools and for that a few hundred pounds is more than enough. The only benefit of the tonnage of the press is if you decide to use it as a clicker also.
I have the same press. I use 3/4" 40 gum rubber on the bottom and 2 - 1" pieces on the top. I pump it until I hear the frame on my press start to groan. That's not actually what I use to gauge it, more feel, but that coincides with what I am doing. If I go to hard it can ruin the nice grain look on the leather.
The only time I've broken a mold is when (I think this is what I was doing,quite a while ago) I had the mold on a hard surface with rubber on top. With nothing to support the trigger guard underneath it cracked it.
It does a pretty good job of pressing it down close to the slide, though I don't leave a lot of room with my stitch lines.
I'm anxious to try vacuum forming someday. Time and money.
Big River Leather
DLCP228MahogcharcoalEleph001small_zpsniz
Here is what Bluegus sent back when I asked about the amount of pressure. I was hoping for a poundage or something like that but it sounds like just trial and error. I guess if it was a big problem they would know more details about it so that is good. I order all my guns without the top coat unless my customer requests otherwise.
" Se sell about 100 Holster makers and have no problems to date from any one. Should be no problems. Remember to tell us when ordering not to put the final finish on the guns as we use a leather dye on the final finish. Carl Ring"
Thank you,
Rob Bennett
BLUEGUNS
Multi Molds
Maker Supplies
FREE SHIPPING!
FACEBOOK
Okay, here are a few photos of what I did the night before last.
One is before any pressing and the other is after pressing. The last, is the holster in the press to try to show the force.
I did not put alot of pressure on it, just untill it got tight.
I am only using 1/2 inch rubber on top and bottom.
Another possible issue is that my top steel plate is not mounted to the ram. I am not sure if this is good, bad or does not matter.
Thanks for the input,
Jim
I am suprised they did not give more detail, guess it is a case of CYA.
Thanks for looking into it for me, i appreciate it!.
post-14605-019191700 1312562700_thumb.jp
post-14605-092869000 1312562718_thumb.jp
post-14605-030994600 1312562861_thumb.jp
