Ok, I know this is probably a stretch and asking allot, but I would like to see how you puffy seat guys (beeze) make your patterns for your seats.
I have a seat that looks like this with the factory cover:
And here is what it looks like uncovered:
What my problem is, is the contours of the foam seat. I took the original vinyl cover, cut it up on the seams, and it is too stretched to give me a good pattern, and i have tried the covering it with plastic then covering it with duct tape to make a cover, draw out my seams and cut it up method.... it is too contoured to make a pattern from. I cant get my head around the contour part of it. This is pretty much what i need explained and shown to me.
Thanks
"The miracle is not how two adults can create a child, the phenomenon is how quickly a child can create two adults." -- VYBE
Her: Hit Me
Him: Do you want me to use the knife?
Her: No, When you hit with a knife, that's STABBING!
well....
you just gotta go for it!
i cut the top the way i want it shaped then cut the side in one piece. i make sure i have way more than i need to wrap the sides and wet the side to get it to conform. this one should be pretty easy.
some of the more extreem/complex seats require me to install the cover and let it sit till near dry or dry and rewet it,drill out some rivets and pull some more but, this one should cover rather easy.
i don't get krazy with making patternz...
thats my main issue when "just going for it".... I get puckers and wrinkles.... I am wasting too much leather on this project.
Her: Hit Me
you just need to pull them out as best you can. make sure it's good and wet then let it dry and see what you get. like i said... some times you have to go back a second time after the leather takes a set. rewet it, take out the pop rivets and pull on it some more.
i generally start at the bend (i'll call it) the widest point where the seat curves up at the back. then i work my way forward then back. i get the easy parts out of the way first and the hardest areas last. that way the water can work on the harder areas longer. don't forget to keep it good and wet during the whole precess
now I am confused....
Are you talking about using one single piece to cover the seat?
Because the way i want to do it is with several sections, one on the seat area, two to make the sides, and one across the back, all laced together. I cant get the leather cut right so it fits right, and cant get my head wrapped around wetting and stretching the leather if I cant get it cut right to begin with.
The way I am looking at doing this is to pattern the leather pieces, finish them, lace them together, and put over the seat and roll under and fasten to the plastic pan. I dont understand about the wet stretching of the leather if it is already finished, and laced. I dont see you being able to wet stretch it once it is finished and laced together.
the lines in the pics below ate where I want the lace seams to be.
Her: Hit Me
because of the way i am covering seats, i finish them after installing the cover.
i got away from using multiple pieces for the sides. i like the cleaner look of no seams.
i would guess the area you are having the most problems in would be the back. it takes a lot of pulling and stretching to get that area to lay right.
Beeze, Isnt that two pieces on that seat with a seam going around the seat?
If it is just one piece, when did you do the lacing? before or after you stretched it?
The parts I am having the most issue with are the sides.... around the contours.
Her: Hit Me
the top is one piece and the side is one piece. it is stitched together before hand
Wolvenstein, here is a picture of whinewine's seat he posted awhile ago. (sorry for always using your pic WW) this pic helped me see how the seat is constructed.
Erie__mike__heather___sue___renfaire_2008__motorcycle_seat_110__Medium_.jpg Erie__mike__heather___sue___renfaire_2008__motorcycle_seat_117__Medium_.jpg
the pattern for the top is laced to the sides (although its only one piece) if this were unlaced the side piece would have a hole in it the same shape as the top piece it would just be a little smaller for overlapping and lacing.
As to wet forming most of the seat guys as far as I can tell dye/stain and seal their seats after they are on the seat.
So it's laced together then you have to wet the sides so it can be formed and stretched around the curves
here is some more pics of the cover i'm doing for this seat
I used two pieces for my sides but it could have been just one
for making patterns for the templates I used construction paper and some heavy fabric. I have read on here to use felt or the clear plastic sheets for overhead projectors. you shouldn't have to make so many pieces. Just have to follow Beeza's instructions and wet! wet! wet! unfortunately it's mostly trial and error for our first few seats.
hope this helps
Scott
You can make your patterns by covering the segments in material/paper and stick pins in it to hold it in place. Draw out your shapes on the pattern material. Depending on the leather you are using the seams are joined using a boot seam. It is just a little more professional looking than a plain or top seam. When you cut out the leather ensure you have also factored in your seam allowance. Sometimes a flexible curve is handy to get the angles of the dangles. These are sold in most places that sell household sewing supplies eg the haberdashery section of Walmart might even have them.
Barra
"If You're not behind the Troops, please feel free to stand in front of them"
