Hi all
My 29 k 72 came new with a modern pedestal and a singer ½ hp clutch motor. But I always hand crank it. I have tried those hollow polyethylene belts with a quick connector; they grip well but are too flexible. I would like to try the solid ones. Sandy, did you weld the belt your self? Is it an easy way to do this without buying some expensive tools?
Here is a German website with endless belts;
http://www.behabelt.com/en/belts/round-belts.html
Thanks,
Trox
Tor
Workshop machines: TSC 441 clone/Efka DC1550, Dürkopp-Adler 267-373/Efka DC1600, Pfaff 345-H3/Cobra 600W, Singer 29K-72, Sandt 8 Ton clicking machine, Alpha SM skiving unit, Fortuna 620 band knife splitting machine. Old Irons: Adler 5-27, Adler 30-15, Singer 236W-100
  • Replies 42
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Thanks for the explanation ... Hey BTW, have you ground down (grinded spoton.gif) the foot on your machine?
Absolutely not! It needs the teeth to pull the material through. The only time ground down teeth would be useful to me would be if I was using the patcher to sew soft or thin veg-tan wallets together, or to attach a Ranger belt strap. With the teeth gone, one would have to greatly reduce the foot pressure, or risk losing feed-ability.
I have a triple feed, high lift, walking foot machine and a Union Lockstitch jumping foot needle feed machine. I use those for belts, holsters and heavy straps. Neither of those machines will mark the leather. I use my patcher for circular items and for patch sewing and repairing rips, handles and zippers in garments and hand bags. I also use it to sew seed bead projects to leather belts. I depend on the teeth being present and accounted for.
Your use may be different and may work fine sans teeth on the foot.
Posted IMHO, by Wiz
I've just been considering removing the teeth lately... and dipping it in that rubberized coating stuff for grip. I think I'll get an extra one and try it.
Does Anyone Know Where the Love of God Goes When the Waves Turn Minutes to Hours?
I was going to suggest buying a spare foot. If your grinding idea doesn't pan out, you're only out the spare foot.
I customized a spare foot on my buddy's Adler 30-70 patcher, to make the left toe very narrow (just enough to hold down the leather as the needle ascends). I also tapered it inward on the front and bottom, to reduce accidentally gouging stuff on the left of the foot. We use this foot to sew very close to formed cases, or jacket snaps, or tough zipper replacement jobs.
Edited by Wizcrafts
Posted IMHO, by Wiz
Yes Trox, I did it myself with just a lighter. Just hold the two ends next to each other and heat them at the same time. Don't let it burn and get black! Then push the ends together on a flat surface so you don't move the ends all the time with your hands. My hands aren't that steady. After a minute or so I put it in cold water to make absolutely sure it is cooled down al through. If you did it right you can pull as hard as you can but it won't break at the weld. I guess you just have to practice a few times. I did.
There is a special tool for it. The mechanic at work showed it to me. Nothing fancy. Just a clamp to hold and push the ends together. And the heating was done with a soldering iron. Instead of a point there was a little metal plate. That's it.
post-23336-001389300 1315252324_thumb.jp
You could cut the exsesive material but it doesn't bother me so I just leave it.
Sandy.
Hi all
http://www.behabelt....ound-belts.html
Thanks,
Trox
Thor, I think your hollow belt is too long if you have problems with the flex. I´m using it on my Adler 105-25 and my Singer 29K without problems , so my advice is to shorten it ( cut out one end of the connector plug with a sharp knife, shorten the belt and reassemble ) The company that sold the hollow belt told me to shorten the belt at least 10% .
/ Knut
Edited by oldtimer
"The gun fight at the O.K. corral was actually started by two saddlemakers sitting around a bottle of whiskey talking about saddle fitting"...
Hi Knut,
I have tried that, you told me the first time, remember. When I stitch thick heavy leather, the hand wheel turns 180 degrees before the needle punch true. For a patcher it is fine, but it is too flexible for my Adler class 5. My speed reducer mounting demands a very long belt. I have changed it back to a V belt. The pulley is made for a round belt and the V belt twists, but it works. The V belt will wear out faster (because of the twisting), it also need more tension to stay on the pulley and will wear on machine bearings. The hollow poly belt has no slippage like a leather belt and is very good on a lighter job. However, I need a solid core one for my class 5.
I just found a company in Oslo that had those German BEHA belt on their web site. It remains to see if they will sell me one. Did the company you bought from have the solid core ones?
Trox
/ Knut
Tor
Thanks Sandy,
I just found an Oslo based company that had the BEHA belts on their website; it remains to see if they will sell me a one. It is an industrial service company, and it has no web shop. The hollow one I got from my Swedish friend Knut (Oldtimer). Where do you buy your belts Sandy?
Trox
Sandy.
Tor
Hi Knut,
Trox
Hey Thor
They have the solid core belts, from 3 mm and up. http://www.kilremslagret.se/system/start.asp?HID=51&FID=49&HSID=606
/ Knut
I buy them at a local shop. As I am not familiar with the measurements and types and such, I just go there and take the pulleys and v-belts with me so I can explain what I am planning to do. It's called ATD. Just a type of store Oldtimer just mentioned. Drive technology store??? In dutch it's called aandrijftechniek. You can buy al kinds and sizes pulley's and v-belts and belts overthere.
Sandy.
Thanks Sandy,
Trox
