Members Dwight Posted September 16, 2011 Members Report Posted September 16, 2011 Markush made an excellent observation on the mag release, . . . I had one lose a mag for me once, . . . really not a good thing. My other comment would be to suggest that the next one you make, . . . put a sweat shield on it. I personally will not wear a holster without one, . . . as the weapon is forever digging in my side, . . . especially when belted in and driving. You're doing good, . . . I was a whole bunch further up the number scale before I produced one that looked as good as this one. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Contributing Member TwinOaks Posted September 17, 2011 Contributing Member Report Posted September 17, 2011 A comment on your boning and its application for retention: Molding the holster to the gun IS critical for good retention, so the more leather you have against the gun = better retention. As you saw with the accessory rail, you can have too much of a good thing. Concentrate on the leather INSIDE the holster and how it contacts the pistol...first. Then, once you've molded the leather to your satisfaction, you can add the aesthetic boning. Here's a tip that should help with that- less is more. While not a minimalist, I am most certainly a pragmatist. One or two strong lines can indicate the shape or features of the pistol without negatively effecting either the leather or the draw. As Katsass pointed out, repeated flexing of the leather pushed into the ejection port will break that leather down. If you're relying on that bit of molding for retention, you'll eventually lose the retentive properties of it. Waaaaaaaaay back when (and thankfully lost in the big crash of '07) I got into an argument with K-man (of K-D Holsters) about holster design. Well, quite a few failed holsters and many moons later, I caught him on here and offered the apology he deserved. He and Jeff (BOOMStick) correctly pointed out that the friction inside the holster is what counts. If boning increases the amount of leather against the flat surfaces (slide, frame, dust cover), then certainly give it a shot. But you don't need to (and shouldn't) try make a mold of the gun in leather. The outward appearance of a holster has very little to do with how well it retains a pistol. There's a tutorial on here by Jim Simmons on how to make a fitted holster in a western rig, and I've tried it. Just like the tutorial says, the holster will hold the gun very snugly.........and it has NO boning on it. That might be worth a read for you to see how the interior of the holster effects retention. Here's the link to that tutorial - http://leatherworker.net/forum/index.php?showtopic=19338 Quote Mike DeLoach Esse Quam Videri (Be rather than Seem) "Don't learn the tricks of the trade.....Learn the trade." "Teach what you know......Learn what you don't." LEATHER ARTISAN'S DIGITAL GUILD on Facebook.
mlapaglia Posted September 17, 2011 Author Report Posted September 17, 2011 Markush made an excellent observation on the mag release, . . . I had one lose a mag for me once, . . . really not a good thing. My other comment would be to suggest that the next one you make, . . . put a sweat shield on it. I personally will not wear a holster without one, . . . as the weapon is forever digging in my side, . . . especially when belted in and driving. You're doing good, . . . I was a whole bunch further up the number scale before I produced one that looked as good as this one. May God bless, Dwight Dwight, Great timing on the sweat shield comment. The photo below I had just finished when I read your post. Its the first draft of the same holster with a sweat shield. First thing I noticed is on the right where the shield leather meets the main body of the holster I am going to have to adjust that part. It needs less of a reverse curve there. No biggie, thats why I make patterns first. A comment on your boning and its application for retention: Molding the holster to the gun IS critical for good retention, so the more leather you have against the gun = better retention. As you saw with the accessory rail, you can have too much of a good thing. Concentrate on the leather INSIDE the holster and how it contacts the pistol...first. Then, once you've molded the leather to your satisfaction, you can add the aesthetic boning. Here's a tip that should help with that- less is more. While not a minimalist, I am most certainly a pragmatist. One or two strong lines can indicate the shape or features of the pistol without negatively effecting either the leather or the draw. As Katsass pointed out, repeated flexing of the leather pushed into the ejection port will break that leather down. If you're relying on that bit of molding for retention, you'll eventually lose the retentive properties of it. Waaaaaaaaay back when (and thankfully lost in the big crash of '07) I got into an argument with K-man (of K-D Holsters) about holster design. Well, quite a few failed holsters and many moons later, I caught him on here and offered the apology he deserved. He and Jeff (BOOMStick) correctly pointed out that the friction inside the holster is what counts. If boning increases the amount of leather against the flat surfaces (slide, frame, dust cover), then certainly give it a shot. But you don't need to (and shouldn't) try make a mold of the gun in leather. The outward appearance of a holster has very little to do with how well it retains a pistol. There's a tutorial on here by Jim Simmons on how to make a fitted holster in a western rig, and I've tried it. Just like the tutorial says, the holster will hold the gun very snugly.........and it has NO boning on it. That might be worth a read for you to see how the interior of the holster effects retention. Here's the link to that tutorial - http://leatherworker...showtopic=19338 Mike, As you and I had chatted before, this one is way too much boning. I think I was going for the same look as the first one I made but that was on 3/4 oz leather so it boned really well and very defined. I certainly over did it on this one. I made the mistake of equating lots of fitted lines with top quality leather work. Back when it was too tight I did go back in and push out the ejection port and the rail points. They still show from the outside but have very little effect on the gun. Thanks for all your help on this one,. You and Katass and everyone else. It's great to have a place to go and ask questions and get a correct answer. Michael Quote The key to immortality is first living a life worth remembering. Bruce Lee
Members jlaudio29 Posted September 17, 2011 Members Report Posted September 17, 2011 Almost everything has been pointed out that needs to be accept what i will add. Your belt slots appear to be way to close to the gun on both side, also you did not seem to curve/mold the slot to fit a belt while you were wet forming this. What will happen with this is that a regular 1/8th in belt will fit through the slots but when you actually got to wear the belt and holster you will find that the belt will push on outward on the back side of the holster while the outter side of the belt slots will be pulling in, this will create a ton of retention. the only way youd be able to get away with this setup with out having to curve/mold the belt slots is to have a flat backed holster to where the entire gun is biased to the outside. Now lets bring a gun belt into the picture, typically thicker than a standard belt, double in most cases, this will magnify the effects i have previously stated almost making it unable to draw the holster. You should make if you have no already some belt dummies of different thicknesses to use during the molding process, for a good example of what i am talking about a forum member named Particle has a 3 part holster tutorial up on youtube, during which he shows how to welt mold with the belt dummy. I hope this makes sense, if it does not please let me know i can post pictures with examples of what i am talking about. Quote
mlapaglia Posted September 17, 2011 Author Report Posted September 17, 2011 (edited) Almost everything has been pointed out that needs to be accept what i will add. Your belt slots appear to be way to close to the gun on both side, also you did not seem to curve/mold the slot to fit a belt while you were wet forming this. What will happen with this is that a regular 1/8th in belt will fit through the slots but when you actually got to wear the belt and holster you will find that the belt will push on outward on the back side of the holster while the outter side of the belt slots will be pulling in, this will create a ton of retention. the only way youd be able to get away with this setup with out having to curve/mold the belt slots is to have a flat backed holster to where the entire gun is biased to the outside. Now lets bring a gun belt into the picture, typically thicker than a standard belt, double in most cases, this will magnify the effects i have previously stated almost making it unable to draw the holster. You should make if you have no already some belt dummies of different thicknesses to use during the molding process, for a good example of what i am talking about a forum member named Particle has a 3 part holster tutorial up on youtube, during which he shows how to welt mold with the belt dummy. I hope this makes sense, if it does not please let me know i can post pictures with examples of what i am talking about. jlaudio2, Your comment about the molding of the belt loop makes sense and its something I will make sure to do on the next one. I've seen the particle video so I can visualize what you are saying. Its a valid point and one I should have thought about. I will disagree with you on the need for more leather between the belt slot and the gun. In an earlier post katsass said, "You also seem to understand that the 'wings' are only out there to provide a place for the belt loops, and more leather is only a detriment to the function of this type of holster." I know this is an area where people disagree with the concept of more vs less space in that area. I agree with the thought that less is better than more as the holster ages. Everyone is allowed their own opinion on this point and I thank you for sharing yours. Michael Edited September 17, 2011 by mlapaglia Quote The key to immortality is first living a life worth remembering. Bruce Lee
Members Big O Posted September 17, 2011 Members Report Posted September 17, 2011 You are the second person to suggest that its a little tight at the back of the holster near the gun butt. I have a lot of room to grab the gun but I may trim the curve a little anyway on the next one. It couldn't hurt to have a little more room. I've got to weigh in on this one. It looks like there's MAYBE a half inch of clearance between the point where the trigger guard meets the frontstrap and the top edge of the holster. Yes, the grip angles up and away, and there's room to wedge your hand partway up there. But that's not ideal. What IS ideal is the ability to get a FULL FIRING GRIP (minus the finger on the trigger) while the pistol is still fully in the holster. With the exception of hunting handguns, folks carry handguns in holsters because they anticipate the possibility of needing the handgun on very short notice to defend their lives. Under those circumstances, the draw is going to be as fast as they can manage it, probably faster than they've ever done it before, and a whole lot sloppier. The more advantages we can give them, the better. One such advantage is lessening the possibility of fumbling the pistol due to a haphazard, partial grip. Yes, on a casual day at the range, it's no problem to wiggle the gun into a proper firing grip after you pull it leisurely from the holster. In extremis, though, it's a big problem. Quote https://www.facebook.com/BigOGunleather
mlapaglia Posted September 17, 2011 Author Report Posted September 17, 2011 I've got to weigh in on this one. It looks like there's MAYBE a half inch of clearance between the point where the trigger guard meets the frontstrap and the top edge of the holster. Yes, the grip angles up and away, and there's room to wedge your hand partway up there. But that's not ideal. What IS ideal is the ability to get a FULL FIRING GRIP (minus the finger on the trigger) while the pistol is still fully in the holster. With the exception of hunting handguns, folks carry handguns in holsters because they anticipate the possibility of needing the handgun on very short notice to defend their lives. Under those circumstances, the draw is going to be as fast as they can manage it, probably faster than they've ever done it before, and a whole lot sloppier. The more advantages we can give them, the better. One such advantage is lessening the possibility of fumbling the pistol due to a haphazard, partial grip. Yes, on a casual day at the range, it's no problem to wiggle the gun into a proper firing grip after you pull it leisurely from the holster. In extremis, though, it's a big problem. Actually the clearence is .6" at the tightest. With my fat fingers I can grab it with no difficulty. That being said, I agree with the statements that it should have more room to better fit everyone in all situations. I have already corrected the curve on the one I am making with a sweat shield. I did not intend to imply that I was not taking the offered wisdom to heart. Those that say my angled version know that I listen to all suggestions. Thanks Big-O for reaffirming the need for the correction. I appreciate it. Michael Quote The key to immortality is first living a life worth remembering. Bruce Lee
Members dickf Posted September 19, 2011 Members Report Posted September 19, 2011 I realize I never responded... I think it looks like it was too wet because, as you said, it was molded twice and is clearly overworked. I'd be interested to see your next one, as I'm sure you've learned a lot from this one. On the subject of the 'wings' of the holster and belt slot placement: I also agree than your slots, specifically the front slot, is too close to the gun. There is no way, when looking at the profile pic (number 4 in your first post of the thread) that I could thread my gun belt through the holster. jlaudio is correct that when worn, the user's curvature of the hip combined with the tension of the belt would put too much inside pressure on the holster. This does three things that are undesirable. First, it's terribly uncomfortable and can hurt your hip bone when worn for extended periods. Second, it puts too much force on the gun in the pocket and will make it an absolute bear to draw (if you can even get the gun out). Lastly, the holster will stick out like a sore thumb because it doesn't have enough leather fore and aft to curve to the user. I submit my crappy drawing to attempt to illustrate my point. The wings are not there to solely serve the slots a place to live - they are essential in setting the platform for the holster itself and dictating it's profile on the wearer. The rear slot (which we want placed close to the trigger guard, but not too close) is responsible for helping to tuck the gun butt into the user's side. The front slot needs enough room to help the holster curve and keep the profile of the holster smooth and flowing with the contours of the body. This advice is from experience - I have holsters in the bin that can't even be drawn from, let alone threaded with a gun belt. Good luck! Quote US GUNLEATHER www.usgunleather.com twitter.com/usgunleather facebook.com/USGUNLEATHER
mlapaglia Posted September 19, 2011 Author Report Posted September 19, 2011 I realize I never responded... I think it looks like it was too wet because, as you said, it was molded twice and is clearly overworked. I'd be interested to see your next one, as I'm sure you've learned a lot from this one. On the subject of the 'wings' of the holster and belt slot placement: I also agree than your slots, specifically the front slot, is too close to the gun. There is no way, when looking at the profile pic (number 4 in your first post of the thread) that I could thread my gun belt through the holster. jlaudio is correct that when worn, the user's curvature of the hip combined with the tension of the belt would put too much inside pressure on the holster. This does three things that are undesirable. First, it's terribly uncomfortable and can hurt your hip bone when worn for extended periods. Second, it puts too much force on the gun in the pocket and will make it an absolute bear to draw (if you can even get the gun out). Lastly, the holster will stick out like a sore thumb because it doesn't have enough leather fore and aft to curve to the user. I submit my crappy drawing to attempt to illustrate my point. The wings are not there to solely serve the slots a place to live - they are essential in setting the platform for the holster itself and dictating it's profile on the wearer. The rear slot (which we want placed close to the trigger guard, but not too close) is responsible for helping to tuck the gun butt into the user's side. The front slot needs enough room to help the holster curve and keep the profile of the holster smooth and flowing with the contours of the body. This advice is from experience - I have holsters in the bin that can't even be drawn from, let alone threaded with a gun belt. Good luck! It had to be molded twice because I did too good of a job molding the detail around the rail and the gun would not come out without two people pulling on it. There was an audible click as each protrusion when past the rail opening. But I agree that I over molded that one. I learned not to, which is the point. Thanks for the picture. My waist has a much larger front end :)but it made the point well. The next one is on the table in paper form as we speak. Its an Avenger type. Once that is done I plan to do the pancake again. The practice will not hurt. Michael Quote The key to immortality is first living a life worth remembering. Bruce Lee
