Members barbiesdude Posted October 18, 2011 Members Report Posted October 18, 2011 Just curious as to what other people use for there foundations for there knots, lets say heel knots, nose buttons, romal rein buttons? I have been using para cord ring knots covered by self fusing silicone tape. It works OK but I would like to get away from synthetics as much as possible. Even though I believe that if the old time Vaqueros had had access to nylon, poly, and such, they would have probably used it. So if people could maybe post there methods of ground work, it may benefit everyone by seeing other ways to do something. Looking forward to it. Jamie Quote
Members Aggiebraider Posted October 18, 2011 Members Report Posted October 18, 2011 The easiest and best way in my opinion is to use a strip of leather and wrap around the body of the piece. I will determine to width of the strip based on the size of the button then skive the ends so they can overlap smoothly. I will take a test strip and wrap it around how ever many times I want and then cut it and cut all of the strips the same size. I use contact cement to glue it all down as I wrap it around I will add some to the inside. Then when its dry, you can either shape it with a knife or shape it on a belt sander which is what I do. If you add successively smaller width strips and wrap them centered on what you already did, you can make the foundations really round. This is how I also do scarf slides. Its a really good way to use up scrap kangaroo since its much easier to wrap around something tight. Hope that makes sense, CW Quote
Members megabit Posted October 18, 2011 Members Report Posted October 18, 2011 I braid almost exclusively in rawhide and seldom use anything other than a knot tied in rawhide as a foundation. If you do a 4 strand ring knot by pushing 2 strands through the body of whatever you are working on, that button isn’t going to ever slide up or down. I will use floral tape to smooth things or as a little filler sometimes. I would only use paracord if project was being done in paracord. I do recall hearing that Bill Dorance would use bondo (I think over a ring knot) as a foundation. I also recall someone telling me they used those balls from bungee cords to make shuflys. I think I might give that a try next time I make a shu fly. Quote
Members Leatherpownder Posted October 18, 2011 Members Report Posted October 18, 2011 Sound advice. Quote
Members curlyjo Posted October 19, 2011 Members Report Posted October 19, 2011 I,ve been using a hot glue gun to even up heel knots and then shaving with a SHARP knife to make it even before putting on the heel knot. For under nose buttons I cut and split a long piece of leather and bevel the edges and wrap to increase the size. But thats only if needed. It,s generally about less than a 1/2" wide and makes the nose button a little more defined. Under small buttons just tuck a small string under the braid 2 or 3 times and it won't go anywhere. I hope this makes sense. Brad Quote
Members barbiesdude Posted October 23, 2011 Author Members Report Posted October 23, 2011 Hey Curlyjo, How do you secure the ends of your leather piece for the nose button? Jamie I,ve been using a hot glue gun to even up heel knots and then shaving with a SHARP knife to make it even before putting on the heel knot. For under nose buttons I cut and split a long piece of leather and bevel the edges and wrap to increase the size. But thats only if needed. It,s generally about less than a 1/2" wide and makes the nose button a little more defined. Under small buttons just tuck a small string under the braid 2 or 3 times and it won't go anywhere. I hope this makes sense. Brad Quote
Members curlyjo Posted October 23, 2011 Members Report Posted October 23, 2011 First thing is I put the foundation to a ring button on each side to hold the nose button in place. Then point the leather strip at an angle and glue the start down. Tie a little piece of string to hold your glued end down. Then wrap the leather all the way to the other end and taper that end and glue and tie down again. I've also used nylon string to firm it up. Don't use jute string unless you cover with tape. All the stringy ends start showing up through the finished knot. Hope this helps. Brad Quote
Members barbiesdude Posted October 23, 2011 Author Members Report Posted October 23, 2011 Yep, Makes sense. Thanks a bunch. Do you use regular contact cement to glue down the ends, and do you glue down all the way across? Quote
Members curlyjo Posted October 23, 2011 Members Report Posted October 23, 2011 Just regular contact cement. And sometimes as I'm winding the leather around I'll put a dab to help hold in place, especially towards the end as it helps hold in place while you finish, trim and glue all at the same time. Brad Quote
Members barbiesdude Posted October 24, 2011 Author Members Report Posted October 24, 2011 Thanks for the tips Brad, I'll be giving it a shot in the next day or two. I've started a hackamore and got the core covered in 12 pl. and the two ring knots on for the nose button. It's gonna be a real "raggy" "floppy" one as I didn't realize that just a 4 strand reata like braid would be that limber when covered. I thought about starting a new one but figured I'd go ahead and finish just to get one under my belt. Jamie Quote
