What is the difference with the Adler 105-64 and the 105-25? I have an adler 105-25mo (who need repairs)
For those who have this machine, what do you use it for?
thanks
thanks
I have the 105-25RM. It is meant for sewing moccasins. I don't use it for that.
I use it to top stitch my kilt straps and belts.
It has a lever to disengage the feed dog.
My machine works extremly well. I have eased up the tension on the presser foot as it tends to mark the leather.
You have a specialty machine for doing Moccasin shoe tops. The ones I have seen have a differential feed that causes that crimped up look. These machines can be "deconstructed" into an "about normal" stitcher by removing most of the gear on the top of the flat bed. What you have depends on the state of "deconstruction". The 105-64 is the predecessor to the 205. It is a medium duty sewing machine with capacity of about .5 inch (12mm).
Art
thanks
