Members DCKNIVES Posted August 12, 2008 Members Report Posted August 12, 2008 Sandy made this from scratch as he does many of his stamps.He uses long stainless hex head bolts 1/4"-5/16" with at least a 4" shank.Shape with files and sanders.Dave Not a good pic just a scan, but it shows some of Sandy's carving and tooling skills in a sheath he gifted me. Quote http://dcknivesandle...lademakers.com/
Members Rolf Posted August 20, 2008 Members Report Posted August 20, 2008 (edited) I just made a smaller burnisher for my Dremel! I got a 1/2"long, 3/8 wide nylon spacer for 25 cents. I hammered a cutting blade mandrel into the hole then used a needle file to shape the groove. Sorry for the cell phone quality. It is great for getting into tight spaces! And I can still use it as a mandrel! wow great tool, thanks for your post and the picture! Edited August 20, 2008 by Rolf Quote Rolf Menzi www.western-wear.ch Switzerland
Members SmkyTheBr Posted August 21, 2008 Members Report Posted August 21, 2008 I used a plastic edge slicker from Tandy and inserted one of the rubber spreader attachments for the Dremel used for the sanding wheels, it fit perfect and works great. Tom Quote
carr52 Posted August 21, 2008 Report Posted August 21, 2008 I made this knife from deer. horn Just drilled a hole for the blade and then drilled and tapped holes on the side to hold the blade in place. Need some kind of finger rest on top. I used it on this holster and it worked fine. Tom Quote
