I was asked to create a pattern with instructions for an upcoming community collage course. Please take a look at this. Comments are welcome. I tend to get long winded with explaining things.
Feel free to use the pattern if you want to make one. This is targeted for a beginning leather student. Someone that has made a kit or two.
Michael
Click here for PDF pattern
The key to immortality is first living a life worth remembering.
Bruce Lee
Thank you for putting this together: A few comments I hope is OK:
1. is is easy to understand
2 Typo in step 1, the word label is misspelled
3. item 10, the word "the" is in the last sentence 2 times
4. define how to stitch and case
good job and good luck
Michael
What is the need to case a knife sheath for a flat knife? Your stitch length; are you actually holding the leather together with that close of a stitch length and that large of a thread?? Just curious.
Wishful,
Thanks for the comments. They are always welcome.
your #1 comment "1. is is easy to understand" Are you saying I have the word is somewhere twice or is that a typo on your part?
I appreciate your looking it over.
Thanks for your time.
Michael.
Bruce Lee
They need to have the leather wet in order to transfer all the lines and marks from the pattern and the instructor requested that I not use terms like dampen or quick case when referring to dealing with the complete piece of leather . If they are going to tool the knife, something i did on the example, they need to have it cased for that too.
Yes, the stitch length and thread size is holding the sheath together. I put one together without any cement and it held fine. I have used that thread and stitch length on holsters and it works great. 6 stitches per inch is pretty standard for that size of leather and the thread is what they will have available to them to use. I didn't want to list something like irish linen 4 cord, 0.7mm which is what I used. Do you see a problem I am not seeing with this?
Michael
Bruce Lee
It is OK for a begginer course.
I give (is this the correct word ?? ) some classes and teach the students to make a pouch style sheath, because it is easier. But for this kind of knife is THE better option.
Great tutorial! I will definitely be referring to it, myself!
I forgot to reply to #4. They cover those two points in the session before this one. So its been taken care of. if it had not been covered already you would have a very valid point.
I have corrected the master for point 2 and 3. Im not sure I can change it here but if I figure it out Ill upload the newer version.
thanks
Michael
Thank you
Michael
Thank you for that comment. Its nice to be able to give back after all the help I have received. You made my day with that remark. :grouphug5vj5:
Michael
Bruce Lee
great tutorial and thanks for the pattern ;-)
Once I moved about like the wind, but now I surrender.(Geronimo)
Failure is always an option
Your welcome.
FYI Everyone,I just noticed that the materials list has a problem. its 12 feet of thread not 12 yards. oops.
Actually its about 8.5 feet but Id rather list a little more than not enough. but 36 feet is a bit much
I have a corrected version here. Updated version Its just the typos corrected. If you have the original you don't need this one but you are welcome to it.
Michael
Edited by mlapaglia
Bruce Lee
