RawhideLeather Posted December 7, 2011 Report Posted December 7, 2011 Howdy all, I am having some trouble with skipped stitches and tried resetting the timing but the manual that came with the machine is pretty much worthless IMO. Anyone know of a video or manual for accurately setting the timing on these Juki clones that is actually comprehensible? I know I could call Cobra Steve for help but would rather have something on hand to refer to occasionally if at all possible. Quote
Moderator Art Posted December 7, 2011 Moderator Report Posted December 7, 2011 Yes, call Cobra Steve and ask nicely for the DVD. Now very seldom does someone knock out the feed timing, usually just the hook timing. So. Put feed leaver in middle. Without thread take the needle all the way down and up 1/8 to 1/4 inch and loosen the bolt for the clamp for the hookshaft on the mainshaft rod, set the hook so it is just intercepting the scarf of the needle and retighten the clamping bolt. That should get you going. Steve can give you more exact measurements. If you need to retime everything, what the hell did you do to it? No panic, it just takes a while, and the DVD. Art On 12/7/2011 at 10:56 PM, RawhideLeather said: Howdy all, I am having some trouble with skipped stitches and tried resetting the timing but the manual that came with the machine is pretty much worthless IMO. Anyone know of a video or manual for accurately setting the timing on these Juki clones that is actually comprehensible? I know I could call Cobra Steve for help but would rather have something on hand to refer to occasionally if at all possible. Quote
RawhideLeather Posted December 8, 2011 Author Report Posted December 8, 2011 Hey Art! I was hoping you would chime in. I have an older DVD that has Cobra Steve in it when he worked for Artisan but it doesn't have anything concerning timing on it to my knowledge. The sound on it doesn't work either on my Mac computer (sounds like chipmunks on helium). Is there a newer one out now or something? Thanks for the timing explanation. That is just what I did but the part about putting the feed lever in the middle throws me. Assuming you are talking about what I call the stitch length lever, I tried moving that around and it has no effect on the needle moving up or down so I don't understand that part of it. What am I getting wrong here? Quote
Moderator Wizcrafts Posted December 8, 2011 Moderator Report Posted December 8, 2011 On 12/8/2011 at 12:07 AM, RawhideLeather said: Hey Art! I was hoping you would chime in. I have an older DVD that has Cobra Steve in it when he worked for Artisan but it doesn't have anything concerning timing on it to my knowledge. The sound on it doesn't work either on my Mac computer (sounds like chipmunks on helium). Is there a newer one out now or something? Thanks for the timing explanation. That is just what I did but the part about putting the feed lever in the middle throws me. Assuming you are talking about what I call the stitch length lever, I tried moving that around and it has no effect on the needle moving up or down so I don't understand that part of it. What am I getting wrong here? By setting the stitch length lever in the middle you neutralize the forward/backward position of the needle bar and feed dog, taking them out of the equation. All you need to adjust it the position of the pickup point, with the needle bar in a centered position, relative to forward and backward. Quote
Scary Leatherworks Posted December 8, 2011 Report Posted December 8, 2011 Well I'm far from qualified on this subject but since I just had a lengthy talk with Steve about timing my class 4 I'll chime in. I was having the same problem with the leather lifting and skipping stitches. The video Steve sends out is helpful with where the bolts are for timing etc... but not very specific. He told me to bottom the needle out and raise it 3/16" exactly. I had to mark the needle (not easy) also put stitch length to "0" then put the hook to so it is just at the needle. now there is some clockwise/counterclockwise play in the hook assembly (sorry don't know the proper term) and I can't remember which way I had it so trial and error for that. I do agree an in depth video for timing would be AWESOME. Quote
RawhideLeather Posted December 8, 2011 Author Report Posted December 8, 2011 Thanks for the clarification on the stitch length lever Wiz. Makes sense now. Scary Leatherworks, I appreciate the input. What you said concurs with what Art said. I had previously moved the position of the needlebar in trying to adjust the timing because I couldn't get the hookshaft bolt loose. Boy was that thing tight! Almost broke my allen wrench getting it loose. Anyway, I hope I didn't mess things up when I moved the needle bar. I moved it back to where I thought it might have been before but it was just a guess really. At least I now have the hook intercepting the needle at the right point I think. Thanks for all the help guys. Hopefully things will smooth out now. This forum is an especially wonderful thing for folks like me who live in a small town far from a big city where one might be able to find a knowledgeable sewing machine mechanic. And of course there is always our good buddy Cobra Steve too. What a nice guy. Quote
Members DDahl Posted December 8, 2011 Members Report Posted December 8, 2011 Hi! I just e-mailed you a copy of the pdf Engineer's manual for the Juki 441. It gives details on ALL adjustments on your machine! I think you will find it is infinitely better than anything you currently have. Happy Holidays! Dave Quote
Members DDahl Posted December 8, 2011 Members Report Posted December 8, 2011 This is the link to the Juki 441 Engineer's Manual pdf file for all who would like THE definitive reference for adjusting their machines! Juki 441 Engineer's Manual Dave Quote
Cobra Steve Posted December 8, 2011 Report Posted December 8, 2011 Hi RawhideLeather. To you and to anyone else who is having a problem with an Artisan, or any other machine, please call me at 1-866-962-9880 and I will do my best to help in any way. We are all in this together and would be more than willing to help you. Thanks, Steve Quote
Cobra Steve Posted December 8, 2011 Report Posted December 8, 2011 On 12/8/2011 at 5:24 PM, Cobra Steve said: Hi RawhideLeather. To you and to anyone else who is having a problem with an Artisan, or any other machine, please call me at 1-866-962-9880 and I will do my best to help in any way. We are all in this together and would be more than willing to help you. Thanks, Steve By the way, it does show the timing adjustments on the DVD that I made, when I worked for Artisan. Thanks, Steve Quote
Members dbusarow Posted December 8, 2011 Members Report Posted December 8, 2011 On 12/8/2011 at 4:10 PM, DDahl said: This is the link to the Juki 441 Engineer's Manual pdf file for all who would like THE definitive reference for adjusting their machines! Juki 441 Engineer's Manual Dave Thank you Dave! Very nice. Dan Quote
