Hi Leatherworkers.
I´ve been spending thousand of hours on the internet finding out about witch sewing machine would be the best for my projects.
The conclusion is the japanese Juki tsc-441. Heard that the US Jukis are crapier than the Japans, could that be true?
There is one catch though.. I´m not a wealthy guy and only the head is 70.000 skr here in Sweden.
And then a 220 v servo motor witch has good power on top.
Does anyone know were in the world I can order this machine at a lower cost?
Or were there might be used ones?
Would be so thankful for some guiding in this..
Mattias
Hi Leatherworkers.
eveMattias
Hej Mattias. Beställ en Cobra av Cobra Steve här på Leatherworker. 2 av mina kollegor här i Sverige har köpt av honom och dom är nöjda. Du beställer då en med servomotor o 220 volt . om budgeten tillåter köp needle positioning system o du kommer att le varje gång du syr. Jag har en Adler med denna bestyckning o det underlättsar livet!
/ Knut
Yea, what Knut said. Steve from Cobra has delivered several machines over there and knows all the shipping stuff. Your budget is good, and you should be able to purchase for considerably less than that, maybe 40.000 SEK, check with Steve on that.
Steve's Website, the machine you want is the Cobra Class 4 with needle positioning motor for 220 volts.
Art
/ Knut
